Go to Post Uncle Sam wants you to watch NERD Vision. - artdutra04 [more]
Unread 23-02-2011, 16:45
Power2U Power2U is offline
FRC #3680
Power2U is an unknown quantity at this point
Minibot Deployment
I've seen several teams use a sliding device on their minibot deployment systems. Does anybody know how this system works?
I am also seeing that their deployment device is swinging from a vertical position... not really sure what causes this to happen!
Unread 23-02-2011, 17:04
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Minibot Deployment
I suggest you look through your kit of parts. I'm sure you'll find more than a couple things that allow linear motion of a slide type.
Unread 23-02-2011, 21:34
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Most teams I have seen doing this (and my own team) use actual drawer sliders to slide the minibot out on. Basically, mount a plate on one of these sliders and attach your minibot to this plate (in a way that it can climb itself off). Then you need to find a way to actuate the drawer sliders. As far as how to actuate this motion, there are various methods I can imagine.
sideways scissor lift
long pneumatic pistons
linear gear and motor
spring loaded, release a locking mechanism
Our team is using a block and tackle system with a 7in stroke cylinder, I don't know how well this will work.
Unread 23-02-2011, 22:19
kulisb's Avatar
kulisb kulisb is offline
AKA: Brad Kulis
FRC #0078 (AIR Strike)
kulisb is a jewel in the roughkulisb is a jewel in the roughkulisb is a jewel in the rough
Check out the Q&A to this post:
http://www.chiefdelphi.com/forums/sh...ad.php?t=92644
Brad
2009-Present: FRC Team 78 AIR Strike, FTC Team 121 Rhode Rage
2004-2009: FRC Team 121 Rhode Warriors
2001-2004: FRC Team 126 GaelForce
Aquidneck Island Robotics (AIR):
www.air4h.org
Pictures:
www.joemenassa.com
Unread 24-02-2011, 00:44
FRC #3680
Brad
Very interesting! Per that robot, would a servo be the mechanism they are using to detach the deployer?
And wow, didn't know latex tubing could be used for that! Thanks for the help!
Unread 24-02-2011, 00:58
pfreivald's Avatar
AKA: Patrick Freivald
Adding "80/20" or "Bosch Rexroth" to your vocabulary might help, too...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 24-02-2011, 01:13
skistunts1's Avatar
skistunts1 skistunts1 is offline
AKA: Jake Salzman
FRC #0100 (The Wildhats)
skistunts1 is an unknown quantity at this point
My team is using drawer slides and we use pneumatic piston with a pulley on the end of it, and a cable around that pulley that attaches to the frame at one end and the back of the drawer slide at the other. It's really fast that way, fast enough in fact to crush the minibot when it hits the pole if we don't put control valves on the cylinder. Then, since we can't pull the minibot back in with the cable around a pulley we just have springs that pull it in.
team100.org
