Go to Post Believe that Dave knows what he is talking about. - JaneYoung [more]
Unread 23-02-2011, 20:42
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
pic: FRC971 2011
Thanks 254
Unread 23-02-2011, 20:44
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: pic: FRC971 2011
Aw man, why couldn't 254 bust those out a few days ago? Could have gotten some beauty shots of Optimus Lime...
Regardless, looking good guys! Have you managed to get that practice bot together? Is that what we're looking at here?
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 23-02-2011, 21:20
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
The picture is our comp bot before going into the bag. The practice bot is almost together. We are considering re gearing to make the rollers faster and elevator scary fast. The bot is rock solid.
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 23-02-2011, 21:56
I hear timing belt elevators are the future.
Unread 24-02-2011, 15:14
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Definitely lighter than chain, less complicated than a worm gear, stronger than cord, more accurate and precise over a four bar arm. Designed right the timing belt elevator is simple to construct, very quick and durable and darn right cheap to build.
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 24-02-2011, 16:00
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Roy
What pitch belt did you use and how did you tension it? We started off with XL belt and ran into issues skipping it at start up. We finally switched to #25 chain and have had no issues since
Unread 24-02-2011, 16:47
9mm wide 5mm pitch GT2. If you read the docs on the belts, the GT2 holds significantly more force before skipping than the XL. For our claw, we aren't tensioning it, and calculated the center distances correctly. For the elevator, there is a screw tensioner that pulls the ends together inside the carriage.
A 20 tooth XL pulley (1/4" wide belt) is rated to 4.6 in-lbs. A 20 tooth GT2 5mm pitch (15 mm wide belt) is rated to 93 in-lbs. An order of magnitude of difference. The two belts I just compared aren't exactly the same in everything but pitch, so the comparison isn't perfect, but it gives you a pretty good idea on why we chose the belt we did. Our elevator should be able to pick up ~100 lbs before the belts skip.
Unread 24-02-2011, 16:51
AKA: Sean
Ahhh yeah GT2 is much stronger. Where did you guys buy belting that long in GT2 pitch?
Unread 24-02-2011, 22:37
SDP-SI has it. It's a bit hard to navigate to, and I think involved a google search. We bought a 40 foot length of it (unfused), and trimmed that to length.
