Go to Post There is no shame in admitting someone is better than you at something doesn't make them a better person just means they have skill you haven't figured out yet. The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Unread 20-02-2011, 20:27
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
Battery Safety - two wrenches on the same battery
I came aross a battery hazard I hadn't thought of before. I asked one of my team members to remove the pigtails (power cable and plug) from an old battery. I'm sure the battery still had charge to it.
She enterprisingly recruited another team member to help, and I saw that each had a wrench on the battery - one on the positive erminal and one on the negative. I immediately asked them to stop. If there's a wrench on each terminal, and the wrenches touch one another, they will short the battery!! Any piece of metal will conduct electricity, not just a wire and not just copper.
FYI, I could envision this happening, especially in a pit if two people change or just tighten connections and are in a hurry. Only one wrench on a battery at a time!
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 20-02-2011, 21:42
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Battery Safety - two wrenches on the same battery
As well-intentioned as this is, just how would the two wrenches contact each other while contacting the terminals? Wrenches aren't exactly as flexible as wires.
Unread 20-02-2011, 21:48
Gimme a large pair of open-end wrenches (uninsulated, naturally) and some electrically-insulated reaching devices and I'll show you. Wrenches slip, wrench ends meet, "nice" shower of sparks.
Or, the human body can conduct electricity. Two students working contact, and the resistance is low enough, not only do you have sparks, but you have two shocked students, literally.
Unread 20-02-2011, 21:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's not hard to short a battery with two wrenches, or a single screwdriver. I warned our students about the dangers several times before they assembled batteries to cables. It's a serious business. Please be careful and think about what you're doing.
Unread 23-02-2011, 22:16
garyk,
the greater danger here is that if the two wrenches touch while both contacting battery terminals, the chance for welding currents to flow is very high. Once the wrenches weld together and to the battery terminals, they will go to several hundred degrees rather rapidly depending on the state of charge. That temperature is also reflected in the battery which causes a rapid pressure rise that can lead to case failure, electrolyte leakage and possible explosion. It is for this reason, all battery terminals must be insulated at all times. Only work on one terminal while the other is insulated. The voltage is low enough that it can't force enough current through your body to be felt unless it is across a very sensitive (read that packed with lot's of nerves) area that is wet like with sweat or salt water.
Unread 23-02-2011, 22:27
pfreivald's Avatar
AKA: Patrick Freivald
Right. The danger with these batteries isn't electrocution, it's the spraying of boiling battery acid all around the general vicinity.
Not good for anyone!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 23-02-2011, 22:46
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The batteries are sealed for that exact reason.
Unread 23-02-2011, 23:02
Max,
The batteries are sealed so that you can use them upside down. The seals will not hold and likely will not be able to vent enough gas in abusive situations like shorted battery terminals. Case failure is the result.
Unread 23-02-2011, 23:05
pfreivald's Avatar
Well, they're sealed so that you can tip them and nothing will spill... But sealed batteries brought to a boil create pressure that will eventually (and in the case of a terminal short that doesn't burn up whatever is shorting them like a fuse, very quickly) rupture the case, allowing the pressurized badness within to escape at high velocity...
Team 1551
I write books, too!
Unread 23-02-2011, 23:25
MrForbes's Avatar
AKA: Jim
This is a serious danger, you can be burned badly by hot wires or wrenches. I've seen it happen.
Unread 24-02-2011, 16:58
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
Max,
I can tell you from experience that a sealed battery will almost defiantly blow up during a fault, actually a non sealed battery probably will too under the proper conditions. And there is usually quite a mess to clean up after.
Put some care into working with batteries everyone. Use insulated tools or wrap regular wrenches and drivers with electrical tape. Same goes for test probes for meters and such, as little exposed metal as possible.
Unread 24-02-2011, 17:03
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
It is quite dangerous, I shorted one of our 2005 batteries with a screwdriver while changing the leads, it wasn't fun...
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 25-02-2011, 15:50
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
I know for a fact that one screwdriver is enough to short a battery if the person is not paying attention. Thats why we have a black burn mark on our famed orange-handled screwdriver now. The kid wasnt paying attention and shorted the battery and got shocked in the process. 2 Wrenches could easily short a battery and shock 2 people instead of just 1.
Unread 25-02-2011, 16:47
12 volts isn't really enough to shock anyone unless it goes through wet skin. The person is likely to be startled (and perhaps slightly stung) by the sparks that fly upon initial contact.
The immediate hazard is from extreme heat as current flows unimpeded through the metal tool. The slightly less immediate but more dangerous hazard is from shrapnel and acid from an exploding battery.
Unread 25-02-2011, 22:57
DonRotolo's Avatar
Back to humble
FRC #0832
Not to mention the sharp and tiny bits of lead and plastic, coupled with globs of strong sulphuric acid. More than enough to ruin your day, week, month and year in a flash.
I, too, have seen the aftermath of a battery explosion. You too would never forget it.
