Go to Post I'm sure there are many people out there who check their rep screen every 20 minutes in hope of positive reinforcement in a unique community, where they may not get positive reinforcement for sharing information in their home, school, or robotics program. - Eugenia Gabrielov [more]
Unread 24-02-2011, 12:50
Team 2524 Team 2524 is offline
FRC #2524
Team 2524 is an unknown quantity at this point
Interpertation on Bumpers: Do the bumpers need to display the team numbers?
We have some old plexiglass that has our team number on it and we were going to mount that on the robot. Do we also need to put the team number on the bumpers?
I was curious since on the 2011 FRC inspection checklist for Logomotion mentions:
"Team number displayed with 4" tall x 3/4" stroke, on the bumpers, 4 locations at approximately 90 deg spacing, in contrasting color or background."
Thank you
Unread 24-02-2011, 12:53
nighterfighter nighterfighter is online now
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Interpertation on Bumpers: Do the bumpers need to display the team numbers?
Yes, it needs to be on your bumpers, both the red and blue.
Unread 24-02-2011, 12:58
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
And for the contrasting color, as a scout/scouting mentor, I strongly recommend something in the white/silver/bright yellow range. Black lettering looks fine close up, but it's nearly unreadable in the stands.
Unread 24-02-2011, 13:01
AKA: Matt B
FRC #1771 (1771)
Yes! We have used a bright white color, and it looks fine on both red and blue bumpers.
If you do use black letters, at least put a thin white outline around them.
Unread 24-02-2011, 13:02
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
If the piece of plexiglass with the team number was fabricated prior to this year's kickoff, you aren't allowed to use it on your robot.
Is it really plexiglass or lexan? I wouldn't recommend using plexiglass on a robot: it will shatter upon impact.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 24-02-2011, 13:07
FRC #2524
It is plexiglass and we still need to cut it.
Unread 24-02-2011, 13:14
Onward through the fog.
Why are you creating room for interpretation when there isn't any?
Jane
~ Helen Keller
(1880-1968)
Unread 24-02-2011, 13:16
Plexiglass, AKA acrylic, shatters on impact. I've seen it happen, back in 2005 (and the robot that did the shattering drove up a steep angle to do it). That's why it's not recommended in any areas on the robot where it might get hit.
You may be thinking of polycarbonate, AKA Lexan, which doesn't shatter nearly as easily.
Unread 24-02-2011, 13:18
FRC #2524
Well, the plexiglass will be located about 2-4ft off the ground. It will be connected the Arm frame which Doesn't hit something on impact >..<
Unread 24-02-2011, 13:33
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I have seen supposedly safe plexi shattered.
There is no safe place on a FRC robot.
Unread 24-02-2011, 13:37
Yep. That acrylic I mentioned earlier--the impact was at about 3.5-4 feet up. The "ramp" that was gone up could slow or stop a robot pretty well-- except that one. The other 3 sides of the tower shielding (running between arm supports) were Lexan and survived the rest of the season, as did the replacement Lexan panel.
Unread 24-02-2011, 15:14
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The best place for acrylic is the trash can. There is never a situation on your robot where it would be a better choice than polycarbonate.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-02-2011, 18:03
GaryVoshol's Avatar
Cogito ergo arbitro
This isn't an interpretation. It's a reading of the rule:
<R09> Teams shall display their team number on the BUMPERS in four locations at approximately 90° intervals around the perimeter of the ROBOT. The numerals must be at least 4” high, at least in ¾” stroke width and in a contrasting color from its background. Team Numbers must be clearly visible from a distance of not less than 100 feet, so that judges, referees, and announcers can easily identify competing ROBOTS.
See how many times "must" and "shall" appear? You have to do it - numbers on the BUMPER, regardless of wherever else on the ROBOT they appear. Period.
(since 2004)
Unread 24-02-2011, 21:36
Let this be your guide... I predict 50% of the robots on the field will have an arm for scoring at least the center rows. That means at least one robot on the opposite alliance in every match will have extensions beyond their frame perimeter. Those arms will reach over six feet and can contact your plastic signage.
Unread 28-02-2011, 07:49
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
For the past, what, 3 years now, we have used plexi for the electrical box, becouse it doesn't bend under load. Never had a problem. Asides from that, true, lexan is much more resilient under shock.
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
