Go to Post Every robot is a key element to each victory, no matter how much or how little they help. - JosephC [more]
Unread 24-02-2011, 13:59
Team 1574's Avatar
Team 1574 Team 1574 is offline
FRC #1574
Team 1574 is an unknown quantity at this point
Minibot Motor Issues
In http://www.youtube.com/watch?v=8lRtC8wBUa0 video, the Tetrix motors are connected directly to a ~1cm axle. According to our calculations at the 154 rpm that the motors output, the minibot should move at about 6 cm/sec. The only way we can think of to make the minibot climb that fast is by removing the gear. Is this Legal?
In addition, we recently found out that there are two different types of Tetrix motors, 739083 and 739023. What is the difference between these two types of motors.
Unread 24-02-2011, 15:59
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Re: Minibot Motor Issues
http://forums.usfirst.org/showthread...ar#post 44890
GDC wrote:
Default Re: Minibot Materials & Modification
2) R47-A allows modification of gear teeth on output shafts. We cannot comment on the general "other external components" clause.
Other related information...
<R47> Motors and servos used on the ROBOT shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface of the motors may be modified to facilitate the physical connection of the motor to the ROBOT and actuated part.
boomergeek musing...
(Gearboxes are typically not considered by FIRST to be "integral" to a motor).
Unread 24-02-2011, 23:52
Power2U Power2U is offline
FRC #3680
Power2U is an unknown quantity at this point
Interesting... What material is that team using on their minibot?
