Go to Post Well I have to admit, most of the people on our team are geeks. I think that it's a title of honor considering it might as well be "boss" or "head supervisor" or something along those lines. - Cyberguy34000 [more]
Unread 24-02-2011, 13:24
Team 2524 Team 2524 is offline
FRC #2524
Team 2524 is an unknown quantity at this point
NXT-Brick for Minibot: We programmed the Minibot on NXT-G so that the motor will....
We programmed the Minibot on NXT-G so that the motor will spin infinitly however it stops after 3-4 spins. We checked the controllers, changed NXT-Bricks, checked wirings and the programming.
Can anyone think of any other reason why the motors would stop after a couple spins?
Unread 24-02-2011, 13:39
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: NXT-Brick for Minibot: We programmed the Minibot on NXT-G so that the motor will.
Is there a reason you're using the NXT-Brick? If you just want the motors to spin indefinitely, then you can wire it as such. There shouldn't be anything too complicated on your Minibot to warrant programming.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 24-02-2011, 13:44
FRC #2524
Well, we don't want the motors to spin after it hits the top of the pole.
Also, we don't want the motors spinning for the entire round.
Unread 24-02-2011, 14:07
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
You could easily design a switch to turn the motors on right before you deploy.
You can also make a switch to turn the motors off.
Unread 24-02-2011, 14:35
Coach Doug Coach Doug is offline
FTC #3529
Coach Doug is an unknown quantity at this point
The " infinite " time control option in the nxt-g motor command is really misleading. There is some sort of time out feature that you can't modify. Just nest that command in an infinite loop and you will have what you are looking for. If it still doesn't last long enough - double nest it.
Unread 24-02-2011, 19:21
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Have you made sure that your program doesn't end? If that block exits, then the program will exit.
On the NXT, with Lego firmware, motors will continue to run for about a second (then coast) when a program exits.
I hope this helps.
