Go to Post I'm sure there aren't a bunch of rule makers sitting in a board room discussing "What rule can we change now to mess with the teams' heads?" Lets all just sit back and enjoy the regionals! - Rick [more]
Unread 24-02-2011, 21:02
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: How Will Logomotion Play Out and Develop?
Originally Posted by Chris is me View Post
How does it take 30 seconds for a kitbot to run across the field twice? You can run a tube in 15 seconds, easily.
This is assuming that one of the runners is completely unable to do anything the second you decide to play defense on them (not true), and it also assumes that the scorer never has an opportunity to take a tube.
You can't take a robot out of a match that easily, between the pinning rule and protected zones.
one thing that may factor into that is an all time high in mechanum drives. personally i think that a good tank drive will be able to push all of the mechanums around without difficulty. thus i conclude that in in elims, where the primary feeders and things to play defense on will be kit-bots (super fast, no pushing power, cant turn well) and mechanums (not as maneuverable on the open feild as a good tank, and not as powerfull either.) thus i think that the stated strategy is only good if you have a custom setup tank, and it is early in the day Friday.
