Go to Post Action x (Passion Vision) = Goal - EricH [more]
Unread 24-02-2011, 22:17
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Team 224 Test Drive
Well this here is just this year robot driving.
Theoretically, out bot goes ~70 mph, but we couldn't test it, as you can see, because we have no traction on that floor.
http://www.youtube.com/watch?v=H4jBDe7yLqQ
Unread 24-02-2011, 22:19
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Team 224 Test Drive
How on earth is your theoretical speed 70mph?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-02-2011, 22:23
Carter12s's Avatar
Carter12s Carter12s is offline
FRC #2036 (Black Knights)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Your structure looks very nice! What weight is your bot thou?? It would seem impossible to get a bot to that speed if it weighed more than about 50 lbs unless you had shifter gearboxes. What gearboxes are you using?
Programing is the real way to build a robot.
Unread 24-02-2011, 22:24
Imaginary Friend
AKA: Kevin Li
Team Role: Student
And the Mechanum wheels don't help the speed either.
Kevin Li
596 - Sciclones
Unread 24-02-2011, 22:31
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
70 mph is 102.667 fps.
It looks like you're using 8 inch mecanums. So... that's a rotational velocity of 154 rotations/sec, or 9240 rpm. That'd require a 0.6:1 reduction on CIMs. At best. Which means your robot wouldn't budge. And seeing as you're it looks like you're using the CIMple gearboxes or the Toughbox Nanos, I don't think your math is right...
Looks like a nice drivetrain though.
Unread 24-02-2011, 22:36
whosdadog's Avatar
whosdadog whosdadog is offline
AKA: Jon
FRC #0295 (Renevatio)
whosdadog is an unknown quantity at this point
I am just going to guess that you added a zero somewhere in your speed calculations. 10fps is much more possible.
Unread 24-02-2011, 22:40
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Guys, I might be wrong but I think they were joking.. I hope they were joking.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 24-02-2011, 22:44
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Indeed. The only way your gonna get that close to that speed is with decagon wheels.
Unread 24-02-2011, 22:57
Carter12s's Avatar
Yeah that or tank treads, they really can crank the friction up and almost double the speed of a bot!
Unread 25-02-2011, 18:29
FRC #1747
Thanks a bunch guys!
Regarding the speed, I didn't really calculate it. A member on the team did it on his iPhone. I personally don't believe myself, but he insists that it is.
Unfortunately, we can't test its actual speed because its bagged up AND we don't have any more carpet to run it on
Our bot weighs roughly 106 lbs
and they are CIMple gear boxes
