Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 24-02-2011, 22:52
Joe Menassa Joe Menassa is offline
Professional Photographer
FRC #0078 (Air Strike)
Joe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud ofJoe Menassa has much to be proud of
Send a message via AIM to Joe Menassa
pic: AIR Strike 78 2011
Unread 24-02-2011, 22:53
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: pic: AIR Strike 78 2011
Hm, I wonder how many teams went for the inside expand this year, this makes 3 that I know of (78,79,1557)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 24-02-2011, 22:58
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Make that 4: 3467
Looking good! Is that a triple jointed arm?
1058 PVC Pirates 2016 - xxxx
Unread 24-02-2011, 22:59
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
Looks like an amazing robot. I am going to guess (by that blue tube near the wrist joint) that you use pneumatics to open the gripper? Good luck this season!
1676 also has an inside expansion gripper.
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Unread 24-02-2011, 23:03
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Originally Posted by BrendanB View Post
Make that 4: 3467
Nope, just two. The angled fixed joint where the gripper meets the wrist piece might be confused as a moving joint.
We did a roller claw in 2007 with good results, but with the varying diameters of the tubs, the tube grabbing sub-team decided to go with the inside grab...that is one part that remains quite similar amongst all the tubes!
It's geared for ~5 fps and ~12 fps...definitely the fastest bot we've built. Solid in practice at our shop...can't wait to test it out on a real field!
FRC78: 2010-Present
FRC121: 2002-2009
Unread 25-02-2011, 08:49
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Looking great, per usual! :-) This year definitely does seem more challenging than 2007 for the roller claws - inflation and tube type compound the difficulties, there! The bent forearm seems like a good solution... essentially optimizes it for high scoring and floor pick-up, I'm guessing? Although I couldn't attend the unveiling, I heard 78's demonstration video was as high-quality as ever! Is it posted online anywhere - I'd be interested in watching it! :-)
Best of luck, AIR Strike!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 25-02-2011, 09:08
AKA: Tom Dolan
The angle made the whole system more compact and pickup made pickup simpler (just rotate wrist down and the grabber engages the tube).
The video is not posted anywhere presently...I'll try to coerce Rick into uploading it sometime soon!
FRC78: 2010-Present
FRC121: 2002-2009
Unread 25-02-2011, 09:56
Nick Rixford's Avatar
Nick Rixford Nick Rixford is offline
FRC #0126 (Gaelforce)
Nick Rixford will become famous soon enough
Send a message via AIM to Nick Rixford
Great looking bot as usual, see you guys in Manchester BAE!
Unread 25-02-2011, 09:57
Back after 4 years off
FRC #5279
Any reason you guys went with the Plaction wheels over the Colson wheels you used in the past?
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 25-02-2011, 10:15
AKA: Tom Dolan
We haven't used Colsons since 2008. Dead axle wheels to me were just easier to work with. Changing tread is a pain though...might look into the old 2008 FIRST wheels. This is a speed game...shouldn't be much pushing!
FRC78: 2010-Present
FRC121: 2002-2009
Unread 25-02-2011, 10:19
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Looking good, guys! Hope you make it into St. Louis so I can see it in person. Good luck next weekend at BAE!
Jeff Waegelin
Unread 25-02-2011, 14:08
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Clean design! Add 1983 to the list of inner grippers. To be honest we're modular though, so with a little more time with the practice robot, we'll make our final decision on our Inner vs. Outer mechanisms. Nice work!
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 23-04-2011, 12:32
TreeGirl27 TreeGirl27 is offline
FRC #0027
TreeGirl27 is an unknown quantity at this point
Congratulations on making it to St. Louis!
Unfortunately I have not had the chance to see your bot perform so I have a few questions about it, if you don't mind.
1.Do you have a minibot?
2. How does your minibot deploy?
3. Where can you score on the rack?
4. Have there been any significant changes to your bot since the beginning of the season?
Thanks so much and I can't wait to see you guys in St. Louis!
Unread 23-04-2011, 15:27
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I'm not from 78, but I can give you some answers based on 2079's scouting data in Boston. (correct me if I'm off on something...I'm sure someone from 78 will give you better answers when they respond).
1. Yes.
2. They have a swing arm that deploys from the side of their robot and contacts the pole. The minibot is spring-loaded back on a platform, and when released it springs toward the pole and drives itself up. Their minibot is in the 1-1.5 second range.
3. All levels.
