Go to Post This, right here, is why I participate in FRC. Changing lives, one corndog at a time. - Jared Russell [more]
Unread 24-02-2011, 22:47
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
resetting window motor driven arm after each round
I have used cd search and looked other places but i can't seem to find a thread on this. since a window motor can't be backdriven we need a way to reset it after each round. we currently have this set-up for our arm.
A window motor is chained to the shaft with our arm on it. the arm is attached by having a metal tube slightly bigger than the shaft slipped over it with the arm welded to this tube. two bolts on each side of the arm go through the tube and the shaft to bind them together. The bolts will eventually be replaced with quick disconnect clips. these clips can be a quick fix for directly after each round by simply removing them but the shaft itself will still need to be reset before our next match. i know we can tether it in our pit and reset it that way but i'd prefer a mechanical fix since we might not have time to tether. i remember a time last year where we got done with a match, walked out of the arena, right past our pit, and we were immediately back in line for our next match. I read somewhere about a mechanical clutch but i don't know how that would be made or implemented
unfortunately our robot is bagged up right now but any help would be appreciated.
Unread 24-02-2011, 23:29
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: resetting window motor driven arm after each round
You can tether in the queing line. We did this before every match, along with many other teams, to precharge our pneumatics.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 24-02-2011, 23:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
that's one big reason why we went with a V belt drive. It slips when it needs to. The problem is after the match, how do you get the robot out the door if the arm is extended straight up?
Unread 25-02-2011, 00:18
Chris is me's Avatar
AKA: Pinecone
We made a custom dog for our window motor sprocket in order to disengage the arm between matches. I'll see if I can get a picture.
Unread 25-02-2011, 00:40
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Remove the master-link in your chain, move the chain and drop the arm, re-apply the link in your pit or in que. Takes 20 - 25 seconds to do with 1 helper.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 25-02-2011, 07:58
Kid,
We wire our motors with Power lock connectors and we have modified a 12 volt drill so that the output of the trigger comes out on Power Locks. When we need to drive a motor, we simply disconnect it from the robot, attach to the drill and press the trigger. We use this method throughout the season to test motors and drive components for which software has not caught up.
Unread 25-02-2011, 10:33
pfreivald's Avatar
AKA: Patrick Freivald
Kid,
Consider this idea well-stolen for next year!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 25-02-2011, 11:43
Da Kid's Avatar
FRC #2957
Kid,
this is a great idea! I'll see if i can find any old 12 volt drills since most people use 18 volts now.
Unread 25-02-2011, 12:02
Kid,
It looks like someone asked if it was legal on Q/A, and the answer was no. See http://forums.usfirst.org/showthread.php?t=17253. However, I'm not sure the GDC read the question correctly, so some followup may be necessary.
Unread 25-02-2011, 12:25
Generator of Entropy
FRC #2973 (The Mad Rockers)
I would also consider that "special equipment" which can't be brought into the arena per T25, since the GDC has ruled pretty narrowly on what's allowed.
We don't plan to have any game pieces in our posession at the end, but if we do (and since the inspection template says we need to demonstrate how we would do it) we will remove the belt from one of the gripper sprockets and rotate it down.
Unread 25-02-2011, 12:47
We design the robot so that game pieces do not need power to remove them. The question was how to return an arm to rest position, I assumed off the field.
Unread 25-02-2011, 13:06
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
The rules only stated that you can't bring the items on to the field....Nothing about once you get your robot off to the side and onto the its cart.
They do this to keep the matches going on time.
Unread 27-02-2011, 21:55
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Team 190 is using a mechanical solution (see attached pictures), similar to what Chris mentioned. We have the motor on a spring-loaded mount, which allows it to be pulled back out of the coupler, and the system rotated out of the way. We still have to power it up in the pits to drive it back to the correct position, but this lets us fold up our systems quickly on the field so they don't get damaged in transit to the cart and back to the pits.
It's fairly easy to do, we used 3" long #10 bolts and lock nuts, some standard SAE washers and springs we had lying around (you can find springs like these anywhere, Home Depot, McMaster, etc.). The plate was made with a band saw, drill press and a hole saw to allow the coupler to fit through. We did cut off the disk on the coupler, but there are ways to make this mechanism that doesn't require that.
The springs don't need to be super strong, since the spline on the coupler does a pretty good job of staying in there. We have about 0.5" inches of engagement on the coupler and it works great.
ID:	10295  Click image for larger version
Unread 02-03-2011, 20:54
Da Kid's Avatar
FRC #2957
does anyone know about a gear box with a wormdrive in it that uses a cim motor? our mentor was thinking about doing this because of the cim motors' strength.
in a related matter, what would the gear ratio need to be for a denso window motor to rotate a 10 lbs, 50 in. arm that extends to 62 in? we want it to not put too much strain so that the thermal breaker doesn't get tripped. we do have a spring on the arm so that makes it a little easier, but what would the gear ratio be without the spring, just to be safe?
Unread 02-03-2011, 21:42
pfreivald's Avatar
That should depend largely on how quickly you intend the arm to rotate.
There is a relationship between torque and power that isn't more than algebra to compute... Do the math -- an engineering mentor or physics teacher can help!
Team 1551
I write books, too!
