Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Unread 24-02-2011, 20:39
2733Programming 2733Programming is offline
FRC #2733 (Pigmice)
2733Programming is an unknown quantity at this point
How many lines of code do you have total?
Just curious what other teams using Java are at. We have about ~1800 at the moment.
Unread 24-02-2011, 20:41
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: How many lines of code do you have total?
Wow!!!!
we have about 140! Why is your code so complex?
Unread 24-02-2011, 20:44
AKA: Garty
Originally Posted by Garten Haeska View Post
Wow!!!!
oh btw we havent included our autonomy and deployment yet!
Unread 24-02-2011, 20:56
FRC #2733 (Pigmice)
Wow!!!!
We made wrapper classes for most of our sensors and control devices so we can get the most use out of the information they provide, we have field oriented swerve drive with several driving modes, many automated processes to make the driver's job more straightforward and less concerned with details, and quite a few extra features that we are very excited about, but are not to be named until our first regional.
Unread 24-02-2011, 21:00
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
All our code put together is ~700 lines. But the main robot class is only ~120.
Drive programming is about 500 of those lines.
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 24-02-2011, 21:13
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now the question here is: what are you more proud of? A ton of complex code, or a very streamline one? Now I am not saying a project that consists of thousands of lines are not efficient, but chances are at this level, it is not efficient...
We currently have about 1500. I probably have to go back and streamline everything.
Edit: I would compare that to being big and slow or being a petite sprinter. Which one will you really be proud of?
Unread 24-02-2011, 21:15
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Our 2010 robot had about ~3500 lines of code spread across ~20 Java source files. It's interesting to note that the files SwerveModule.java and Config.java each had a total of 228 lines, the same as our team number.
This season is still a work in progress, but when it's all done I'd expect only around half of that.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 24-02-2011, 21:37
FRC #2733 (Pigmice)
I'm proud of elegant code, that successfully, consistently, and effectively completes the job it was made to do. I'm not encouraging over-complex, or bloated code, but I strongly believe in code that gets the job done, regardless of how many lines it takes.
So to answer your question, I'd be proud of whoever wins the race
Unread 24-02-2011, 21:40
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Well you and I have totally different mentalities then. I am going to use inline assembly next year to squeeze out more juice and performance from the cRio. I know I sound crazy, but I love the low level. I kind of regret using Java. I had to because no one knew C++. I'll go with my wishes before I graduate.
Unread 24-02-2011, 22:30
spartango spartango is offline
FRC #0192 (GRT)
spartango is an unknown quantity at this point
2010 season we had 11,358 lines. 3,036 of those were comments. EDIT: 96 Framework source files, 7 Robot specific files.
2011 season uses the same core codebase of 9,571 lines, 2,749 of which are comments.
Sounds like a lot of bloat, but its not. All together it makes for a really elegant system with abstraction and events and so on--
http://code.google.com/p/grtframework/
Unread 24-02-2011, 23:12
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
I have only 600 lines of code including my various wrappers.
The Reason why is that i use this formatting for eveything
type some_function(type var) {
    do_funky_crap();
class team2412(GP):
    def __init__(self):
        GP.__init__(self)
        self.coopertition = True
        self.info = {"name": "Robototes", "school": "Sammamish High School, Bellevue, WA"}
        assert self.kind_people == True
Unread 24-02-2011, 23:32
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Woah, how did you manage to find the time to code that? Pretty impressed.
Unread 25-02-2011, 08:07
yclee31's Avatar
yclee31 yclee31 is offline
Programmer, Electrical, Design, etc
AKA: MINS
FRC #2429 (LCEC)
yclee31 is a jewel in the roughyclee31 is a jewel in the roughyclee31 is a jewel in the roughyclee31 is a jewel in the rough
Thumbs up Re: How many lines of code do you have total?
are any of you guys using CAN?
Unread 25-02-2011, 11:57
FRC #0192 (GRT)
heh, time... well actually it didn't take that long in that you can generate some of the code, and then also it carries over year to year so once you have the framework you only add a few hundred/thousand onto it specific for each year.
btw, grtframework has/uses CAN, complete with the neat jag closed loop mode.
Unread 01-03-2011, 07:05
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Some interesting stats about our code.
Java.
6 Coders.
1,721 Lines of code total.
Average of 286.8333333 lines per coder
8 Packages
Average of 2.625 files per package
Average of 215.125 lines per package
21 files total
Average of 3.5 files per coder
Average of 81.95238095 lines per file
Interesting facts:
Our neatest code to date
Our first year with our code online
Our Highest number of programmers this year(up 3 from last year)
Our Highest number of source files and packages
Our code: (Will be revised up until our last match!)
http://code.google.com/p/frc399-2011-code-james-bot/
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
