Re: resetting window motor driven arm after each round
that's one big reason why we went with a V belt drive. It slips when it needs to. The problem is after the match, how do you get the robot out the door if the arm is extended straight up?
We made a custom dog for our window motor sprocket in order to disengage the arm between matches. I'll see if I can get a picture.
Remove the master-link in your chain, move the chain and drop the arm, re-apply the link in your pit or in que. Takes 20 - 25 seconds to do with 1 helper.
Kid,
We wire our motors with Power lock connectors and we have modified a 12 volt drill so that the output of the trigger comes out on Power Locks. When we need to drive a motor, we simply disconnect it from the robot, attach to the drill and press the trigger. We use this method throughout the season to test motors and drive components for which software has not caught up. |
We don't plan to have any game pieces in our posession at the end, but if we do (and since the inspection template says we need to demonstrate how we would do it) we will remove the belt from one of the gripper sprockets and rotate it down. |
#9
We design the robot so that game pieces do not need power to remove them. The question was how to return an arm to rest position, I assumed off the field.
#10
They do this to keep the matches going on time. |
#11
Team 190 is using a mechanical solution (see attached pictures), similar to what Chris mentioned. We have the motor on a spring-loaded mount, which allows it to be pulled back out of the coupler, and the system rotated out of the way. We still have to power it up in the pits to drive it back to the correct position, but this lets us fold up our systems quickly on the field so they don't get damaged in transit to the cart and back to the pits.
It's fairly easy to do, we used 3" long #10 bolts and lock nuts, some standard SAE washers and springs we had lying around (you can find springs like these anywhere, Home Depot, McMaster, etc.). The plate was made with a band saw, drill press and a hole saw to allow the coupler to fit through. We did cut off the disk on the coupler, but there are ways to make this mechanism that doesn't require that. The springs don't need to be super strong, since the spline on the coupler does a pretty good job of staying in there. We have about 0.5" inches of engagement on the coupler and it works great. |
#12
does anyone know about a gear box with a wormdrive in it that uses a cim motor? our mentor was thinking about doing this because of the cim motors' strength.
in a related matter, what would the gear ratio need to be for a denso window motor to rotate a 10 lbs, 50 in. arm that extends to 62 in? we want it to not put too much strain so that the thermal breaker doesn't get tripped. we do have a spring on the arm so that makes it a little easier, but what would the gear ratio be without the spring, just to be safe? |
#13
There is a relationship between torque and power that isn't more than algebra to compute... Do the math -- an engineering mentor or physics teacher can help! |
#14
That means you need about a 7:1 reduction with a single window motor. That'll give you an angular velocity of about 12 rpm. You also should design it so that the window motors don't operate at their max stall torque, so you may actually need to increase the reduction some more or add another motor. |
#15
If you're to just use one CIM motor to drive this setup, I'd expect a noticeable reduction in speed as you'll probably be driving the motor somewhat close to it's stall condition. Our arm is designed to still limp along even if one motor happens to die during a match. Don't be fooled by the size of the motor; the F-P motors have the highest power ratings of all the motors available to us. |
