Go to Post I hope that all of our new members are as helpful as the one above. We will be in for an amazing season if that is the case. - Greg Needel [more]
Unread 25-02-2011, 00:18
Chris is me's Avatar
AKA: Pinecone
Re: resetting window motor driven arm after each round
We made a custom dog for our window motor sprocket in order to disengage the arm between matches. I'll see if I can get a picture.
Unread 25-02-2011, 00:40
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Remove the master-link in your chain, move the chain and drop the arm, re-apply the link in your pit or in que. Takes 20 - 25 seconds to do with 1 helper.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 25-02-2011, 07:58
Kid,
We wire our motors with Power lock connectors and we have modified a 12 volt drill so that the output of the trigger comes out on Power Locks. When we need to drive a motor, we simply disconnect it from the robot, attach to the drill and press the trigger. We use this method throughout the season to test motors and drive components for which software has not caught up.
Unread 25-02-2011, 10:33
pfreivald's Avatar
AKA: Patrick Freivald
Kid,
Consider this idea well-stolen for next year!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 25-02-2011, 11:43
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
Kid,
this is a great idea! I'll see if i can find any old 12 volt drills since most people use 18 volts now.
Unread 25-02-2011, 12:02
Kid,
It looks like someone asked if it was legal on Q/A, and the answer was no. See http://forums.usfirst.org/showthread.php?t=17253. However, I'm not sure the GDC read the question correctly, so some followup may be necessary.
Unread 25-02-2011, 12:25
Generator of Entropy
FRC #2973 (The Mad Rockers)
I would also consider that "special equipment" which can't be brought into the arena per T25, since the GDC has ruled pretty narrowly on what's allowed.
We don't plan to have any game pieces in our posession at the end, but if we do (and since the inspection template says we need to demonstrate how we would do it) we will remove the belt from one of the gripper sprockets and rotate it down.
Unread 25-02-2011, 12:47
We design the robot so that game pieces do not need power to remove them. The question was how to return an arm to rest position, I assumed off the field.
Unread 25-02-2011, 13:06
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
The rules only stated that you can't bring the items on to the field....Nothing about once you get your robot off to the side and onto the its cart.
They do this to keep the matches going on time.
Unread 27-02-2011, 21:55
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Team 190 is using a mechanical solution (see attached pictures), similar to what Chris mentioned. We have the motor on a spring-loaded mount, which allows it to be pulled back out of the coupler, and the system rotated out of the way. We still have to power it up in the pits to drive it back to the correct position, but this lets us fold up our systems quickly on the field so they don't get damaged in transit to the cart and back to the pits.
It's fairly easy to do, we used 3" long #10 bolts and lock nuts, some standard SAE washers and springs we had lying around (you can find springs like these anywhere, Home Depot, McMaster, etc.). The plate was made with a band saw, drill press and a hole saw to allow the coupler to fit through. We did cut off the disk on the coupler, but there are ways to make this mechanism that doesn't require that.
The springs don't need to be super strong, since the spline on the coupler does a pretty good job of staying in there. We have about 0.5" inches of engagement on the coupler and it works great.
ID:	10295  Click image for larger version
Unread 02-03-2011, 20:54
Da Kid's Avatar
FRC #2957
does anyone know about a gear box with a wormdrive in it that uses a cim motor? our mentor was thinking about doing this because of the cim motors' strength.
in a related matter, what would the gear ratio need to be for a denso window motor to rotate a 10 lbs, 50 in. arm that extends to 62 in? we want it to not put too much strain so that the thermal breaker doesn't get tripped. we do have a spring on the arm so that makes it a little easier, but what would the gear ratio be without the spring, just to be safe?
Unread 02-03-2011, 21:42
pfreivald's Avatar
That should depend largely on how quickly you intend the arm to rotate.
There is a relationship between torque and power that isn't more than algebra to compute... Do the math -- an engineering mentor or physics teacher can help!
Team 1551
I write books, too!
Unread 02-03-2011, 21:54
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Just do the math. 10lb *16oz/1lb * 62in = 9920 oz*in. A window motor's stall torque is 1501 oz*in.
That means you need about a 7:1 reduction with a single window motor. That'll give you an angular velocity of about 12 rpm. You also should design it so that the window motors don't operate at their max stall torque, so you may actually need to increase the reduction some more or add another motor.
Unread 09-03-2011, 02:18
Torbots 1197 Torbots 1197 is offline
Chief Tormentor
FRC #1197 (TorBots)
Team Role: Communications
Torbots 1197 is an unknown quantity at this point
We're powering our arm through a combo of a fisher-price and RS-775 motors. The F-P is fed into a banebots P60 gearbox with a 20:1 reduction and the 775 through a P60 with a 16:1 reduction. The output of both motors are then fed into a torque summing gear that is also tied to a custom 30:1 worm gear setup. For us, this results in around 20 RPM at the output of the worm gear under a load.
If you're to just use one CIM motor to drive this setup, I'd expect a noticeable reduction in speed as you'll probably be driving the motor somewhat close to it's stall condition. Our arm is designed to still limp along even if one motor happens to die during a match. Don't be fooled by the size of the motor; the F-P motors have the highest power ratings of all the motors available to us.
Unread 09-03-2011, 06:14
Electrical Engineer
Rookie Year: 1995
Originally Posted by Torbots 1197 View Post
...Don't be fooled by the size of the motor; the F-P motors have the highest power ratings of all the motors available to us.
Brrraaappp! That's one down, Kitty Carlisle...
Are you saying that the posted motor specifications are incorrect?
The CIM has a peak mechanical power of 340W versus the FP at 292W. Add to this the additional gear reduction required to gear down an FP, and the CIM wins every time.
Now, if your intention is to build a smoke generator, the FP is a natural choice...
JMHO,
Mike
Mike Betts
As easy as 355/113...
