Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 24-02-2011, 20:23
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Virtual cRio?
is there any type of online virtual program to download code to and test it for auto mode?
Unread 24-02-2011, 20:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Virtual cRio?
There is a VXWorks emulator, but I doubt that is what you are looking for. I doubt there is a cRio emulator out there. Just put it on blocks and see how it reacts. Even better. Actually go through the code step by step in your mind and consider all different situations.
Unread 24-02-2011, 20:32
Re: Virtual cRio?
well we already baged the robot since the bag date was the 22nd
and im just looking for a virtual robot to run my auto mode if possible
Unread 24-02-2011, 20:33
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Virtual cRio?
You should have kept the electronics board and tested with an older robot or something. I highly doubt there is any... I suggest making one.
Unread 24-02-2011, 20:34
Re: Virtual cRio?
i wouldn't know where to start to make my own
Unread 24-02-2011, 21:43
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: Virtual cRio?
I've wondered about this topic a lot. There are many reasons a virtual target would benefit the teams. Maybe it is possible to install vxWorks or the cRIO base image on a virtual machine using something like vm ware. But most likely it isn't that straightforward. Even with the OS running in a virtual machine you need some way to simulate all the I/O. One of the mentors on our team works for a company that develops software for vxWorks and he said they have some kind of vxWorks emulator (I think it is homegrown) that runs on Linux. I would definitely like to see this topic get discussed a bit more here though!
Unread 24-02-2011, 22:14
Re: Virtual cRio?
I heard rumors last year at nationals about a unknown team making a emulator. Anyone trying to make one?
Unread 24-02-2011, 23:30
CodeMonkeyMatt CodeMonkeyMatt is offline
FRC #2605
CodeMonkeyMatt is on a distinguished road
Re: Virtual cRio?
Is it possible this is what you're looking for?
http://firstforge.wpi.edu/sf/project...b_test_harness
Unread 25-02-2011, 00:37
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Virtual cRio?
Yes, I started working on that, and it even works for the most part for some limited things. However, I haven't needed it over the last two years, so development work has been stagnant. And this year, we're using python, so I'm exploring some other options instead.
Feel free to pick up where I left off
Unread 28-02-2011, 22:31
brian3795 brian3795 is offline
FRC #3795
brian3795 can only hope to improve
Re: Virtual cRio?
Is that the most recent code you linked to? Your blog mentioned an non-existent project on GoogleCode...
Unread 28-02-2011, 23:23
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Re: Virtual cRio?
Doesn't Windriver some with some sort of "kernel image"? I suppose you can use that on qemu....
JabbaScript
Unread 01-03-2011, 00:19
virtuald's Avatar
RobotPy Guy
Re: Virtual cRio?
Yes, the FIRST Forge project is the most recent one.
Unread 01-03-2011, 04:52
Re: Virtual cRio?
Have fun simulating the FPGA to get QEMU to do anything useful with that kernel image... It's easier to just rewrite the low level classes in WPILib to pass on the calls to a virtual robot.
