Go to Post Inventions are not built using premade parts. People come up with new ideas, from different angles and with renewed enthusiasm. Playing the game is fun, building and designing is inspirational. - Steve W [more]
Unread 25-02-2011, 11:18
Team 2524 Team 2524 is offline
FRC #2524
Team 2524 is an unknown quantity at this point
Robot is unresponsive: Right motor keeps moving
The second we turned on the breaker, one side of the motor keeps on going and unresponsive. We are driving it in arcade mode. Our robot was moving left when we wanted to turn it right and vice-versa. During the practice run I unplugged and switched the PWM cables for the motors and it worked fine for a couple seconds and then one side of the motors started moving by itself. Now the other side of the motor looks like its leaking fluid (grease I assume) from the gearbox.
I tried to delpoy the code again to the robot but it is unresponsive.
It's Hard to explain >.<
Need Major Help
Unread 25-02-2011, 11:39
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
Re: Robot is unresponsive: Right motor keeps moving
My guess would be to format the cRIO and deploy your code again. I had a similar problem about 2 weeks ago, where all the motors would spin right when i hit enable on the driver station. I had nothing wrong with the code, so i figured it was worth a try. Well, it worked. Let me know if this helps
Unread 25-02-2011, 11:45
FRC #2524
After closer inspection the Jaguar on the right is still supplying power but, is not blinking at all. THe fan is stuck. Help please
Unread 25-02-2011, 11:46
FRC #4272
I would then try to find another jaguar from another team.
Unread 25-02-2011, 11:57
FRC #2524
Does that mean we blew out a jaguar?
Unread 25-02-2011, 12:01
FRC #4272
Its possible. When you said that the jaguar is supplying power, and not blinking, and the fan was stuck, I am assuming that is with the power on. I would probably try another jaguar
Unread 25-02-2011, 12:04
It still might be a code problem.
Does the Jag still generate power if the PWM is completely disconnected?
I'd fall back to testing it with a basic default example, such as the LabVIEW FRC motor example, before declaring it to be an electrical problem.
Unread 25-02-2011, 12:08
FRC #2524
Yes, it still spins after the PWM cable is disconnected.
We tried connecting it to another jaguar and switched the PWM cable and it flashes red on the new jaguar.
So how would i code it again?
Unread 25-02-2011, 12:46
Flashing red usually means it's trying to draw too much power through the Jag, often due to a stalled or seized motor or mechanism.
Testing with default coding depends on the language you're using.
Unread 25-02-2011, 13:44
FRC #2524
We are using labview and I am so lost on what to do . Need urgent help
Unread 25-02-2011, 13:57
To eliminate software as a possibility, in LabVIEW, the start page has a link in the lower right to FRC Examples. Go there, to the Robot & Motors examples to test a generic Arcade Drive.
Make sure to change the project IP to your own and just use the "Run" button. Don't bother to download it.
Another test is to move just the PWM end plugged into the Jag to the working side. Leave the Digital Sidecar end alone. That'll tell you if your code is working correctly.
Electrical:
You swapped out for a different Jag. That's probably the easiest way to check.
Mechanical:
Is the drive train easy to turn by hand on the side that's giving you trouble?
The gearbox could be giving too much resistance.
