Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 25-02-2011, 20:34
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Starting With Ubertubes
Originally Posted by tomy View Post
My team is using a claw this year. The claw is driven by a motor to open in close. How are we supposed to put the tube into our claw without going into telop mode? Are we allowed to force the tube into our claw or do we have to set it on the robot?
Thanks
Team 3038
It has to start touching your robot whether it be a bumper of on your claw within your starting zone. You cannot power up the robot when it is one the field and if they are giving teams the ubertubes early has not been stated and is highly unlikely. If the claw is driven by something other than a window motor or a motor with a worm gearbox you should be able to open it by hand. If not you may have to adjust your auto program to pick it up off the ground.
1058 PVC Pirates 2016 - xxxx
