Go to Post Any FIRST pit is my favorite because that means I'm enjoying a FIRST competition so I'm just plain happy anyways. - Koko Ed [more]
View Poll Results: Will we see a sub 1 sec mini bot?
Yes 93 41.89%
No 129 58.11%
Voters: 222. You may not vote on this poll
  #46   Spotlight this post!
Unread 24-02-2011, 22:03
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
Re: Under 1 sec mini bot
Originally Posted by davidthefat View Post
Now, if a team had a minibot that was an "arrow"... I see a sub .5 sec bot
That arrow better have a tetrix motor propelling its vertical motion.. as well as a battery.
  #47   Spotlight this post!
Unread 25-02-2011, 09:24
Tobot Tobot is offline
AKA: Toby
FRC #1827 (Robojackets)
Tobot is just really niceTobot is just really niceTobot is just really niceTobot is just really nice
Originally Posted by BrendanB View Post
We geared ours for a 3 to 1 ratio. Some teams have opted for just direct drive to eliminate parts to make it lighter.
It is all about finding a balance!
I predict that all of the fastest minibots will mount their wheels directly on the motor shafts. Our minibot team identified this as a necessity very early. Unfortunately we didn't have the fabrication abilities or man-hours to make it happen on our minibot.
  #48   Spotlight this post!
Unread 25-02-2011, 09:28
AKA: Toby
Originally Posted by Alan Anderson View Post
Minibot speed is all about getting the gearing and traction right.
It would have been a more interesting engineering challenge if that were true. Team 1827 will contend that minibot speed is actually all about eliminating every gram that isn't mandated by the rules.
  #49   Spotlight this post!
Unread 25-02-2011, 09:32
pfreivald's Avatar
AKA: Patrick Freivald
We've got a solid 2.5-second minibot without doing that, but every attempt we have made to do a direct-mount has resulted in a bot that does not have the torque to climb.
I know it's possible because I've seen it done, we just can't seem to figure out how to do it! (Though we'll be spending a long Saturday tomorrow trying more ideas... We'd be working today if not for the Snowpocalypse.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #50   Spotlight this post!
Unread 25-02-2011, 10:06
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
This is true, to a point. Once every gram is eliminated, how do you make it faster? If you have a few weeks until your competition, I'd suggest exploring how (subject to your capabilities and resources).
I may investigate a direct-drive option this weekend; though we also need to do a better "V" for the deployment mechanism.
As for minibot that takes less than 1 second to go > 7.5 feet? Well, I've had a bit of foot-in-mouth about minibots this season so I won't really comment on it.
GitHub
  #51   Spotlight this post!
Unread 25-02-2011, 13:16
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Alan is absolutely correct. You will understand it when you get there. This isn't a meant to be insulting, just noting that it takes a lot of experimentation or very thorough design to not "luck" into a fast minibot.
Yes, weight is important, but so is frictions, traction (yes different), load distribution, and most important a matched gearing to the above parameters. When your gearing matches those, you get a very fast (maybe not 1 second, but fast none the less). We had 2 mini-bots of similar design, similar gearing, but one was significantly faster. Then we found and eliminated some scrub, and the slower one was significantly faster than the original fast one. After that, we got them both within 10% of each other with regards to run to run variability.
As JVN points out, iteration is often the key to incremental improvement. We tried approximately 5 "styles" of minibots before settling on an architecture that we liked. We have since gone through 7 different minibot chassis for this particular "style" of minibot. For those of you counting at home, that is around 12 minibots, and I hope to continue as i would like to revisit a completely different "style" that I am seeing get good results. It didn't have good results in Week 5, so we put it on the shelf to be revisited at a later date.
  #52   Spotlight this post!
Unread 25-02-2011, 13:59
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Team 190 has quite the out of box approach to accomplishing the minibot task.
I recommend that come the WPI regional, watch match videos just to see it.
I am sworn to secrecy, but I will tell you this much, it's pretty brilliant.
  #53   Spotlight this post!
Unread 25-02-2011, 16:26
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
oops
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
  #54   Spotlight this post!
Unread 25-02-2011, 16:36
Migriemsl Migriemsl is offline
AKA: Marcene Grimsley
FRC #3743 (Eaglebots)
Migriemsl is an unknown quantity at this point
The trick isn't the motor, but what you use for traction.
  #55   Spotlight this post!
Unread 25-02-2011, 23:04
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
There are teams out there that have to be working meticulously on this right now. They aren't going to give up because of it. Trust me, there will be a sub 1 second minibot.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
  #56   Spotlight this post!
Unread 25-02-2011, 23:24
President, VEX Robotics, Inc.
No way. Not including deployment.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #57   Spotlight this post!
Unread 25-02-2011, 23:32
rcmolloy's Avatar
Remote Mentor
I didn't add deployment factor to the post did I. I'm strictly just talking about the minibot. Quickest minibot plus deployment will be around 1.75 seconds. Maybe not, if so, prove me wrong.
  #58   Spotlight this post!
Unread 26-02-2011, 01:52
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
They will.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
  #59   Spotlight this post!
Unread 26-02-2011, 09:33
ThaineP
Posts: n/a
That would be tricky, since clipping to the pole requires turning a horizontal force to a vertical force, and you can't leave too early after clipping because the minibot would bounce and slide around.
Our team bounced around an idea about a modified clay-pigeon launcher type thing that slams the robot onto the pole (lightly), but would deploy extremely fast.
We haven't had time, money, or enough of a workforce to build it or the minibot, so if anyone wants to use the idea, feel free.
  #60   Spotlight this post!
Unread 26-02-2011, 09:56
mwtidd's Avatar
AKA: mike
Actually it doesn't....
Unfortunately I can't say more.
