Go to Post When you start new threads, keep in mind that ChiefDelphi has about 14.6 million subforums about nearly everything you can imagine in the world of FIRST. You have to be in the forum you'd like for your thread to appear in when you choose to start a new topic. - Madison [more]
  #46   Spotlight this post!
Unread 26-02-2011, 17:14
Koko Ed's Avatar
Happy Birthday! Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: So how many of you actually have a working minibot/deployment?
Originally Posted by pfreivald View Post
I think there were two (2) successful MINIBOT deployments at the RaChaCha Rally (a big thanks to 1511 for hosting!)
We did it once, and then tried something different where we thought that perhaps our MINIBOT might fall out... and it did... After that we didn't load it onto the robot again, happy that what we have works the way we want it to work.
Other than that and one team I didn't get a chance to see, quite a few attempts but nothing successful.
191 managed to put up two complete logos, though, with an autonomous ubertube scored -- very impressive!
MINIBOT RACE!!!
  #47   Spotlight this post!
Unread 26-02-2011, 19:04
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Haha nice one Koko. I hope that we see more minibots (and successful deployments) at FLR.
  #48   Spotlight this post!
Unread 26-02-2011, 19:19
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Originally Posted by Bruceb View Post
We have one.
See it here.
http://www.youtube.com/watch?v=hvrbb9g9EHM
Hope I did that right.
Bruce
You may want to reference this answer in Q&A.
http://forums.usfirst.org/showthread.php?t=16981
If your minibot is above the plane of the deployment line when it crosses the plane of the tower it is illegal.
  #49   Spotlight this post!
Unread 26-02-2011, 21:03
Alex270 Alex270 is offline
FRC #1987 (Broncobots)
Alex270 is an unknown quantity at this point
1987 has one. It doesn't work too bad (deploys and climbs in about 3.5-4.5 seconds). We may tweak the design a bit though to improve this.
  #50   Spotlight this post!
Unread 26-02-2011, 21:28
pfreivald's Avatar
AKA: Patrick Freivald
Sweet! We spent today making it (almost) twice as fast... Almost exactly 2.0 seconds with deployment.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #51   Spotlight this post!
Unread 27-02-2011, 10:15
ThaineP
Posts: n/a
No FTC team, no extra money, no time, no minibot.
Though we did have an idea for a trap-launcher like arm that puts the minibot on the pole.
  #52   Spotlight this post!
Unread 27-02-2011, 11:07
Saber Robotics Saber Robotics is offline
FRC #2506
Saber Robotics will become famous soon enough
Originally Posted by DonRotolo View Post
Get more motors. Break them instead of your 4 second minibot. You can't learn anything without breaking some stuff.
Inside you'll find four gears. Most of them match up with the others easily - that is, they (almost) all have the same "pitch". So, no need to buy more gears.
Play around with them for a while, figure out the output gear ratios for different combinations that can work, and write them down. (Note that the 'height' of the gears might not be right, sometimes you need to make spacers for the gears to get them the right height. The gear on the output shaft might need to be pressed off and you'll have to figure out how to hold it on at a different spot)
Then do the same for the tetrix gears and wheel combinations, then calculate the 'motor to wheel' gear ratios.
Pick a bunch of them - one at each end, a couple in the middle - to try out, see which works best. Keep careful notes of everything you do. Once you have the 'best', try more ratios that are closer to the 'best', and find the 'new best'. repeat until you have the best of the best, and build your minibot.
Does this process make sense to you? Of course, you need to do perhaps ten of these 'experiments' a day. Try to keep the weight of the frame of the minibot the same, make a switch system to start and stop it automatically, use a fresh battery every 4-5 runs, all to eliminate any variables that could fool you.
Good Luck.
Now that helps a lot! Thanks so much and I believe in my minibot team to figure it out.
  #53   Spotlight this post!
Unread 27-02-2011, 13:26
Ashley Painter's Avatar
Ashley Painter Ashley Painter is offline
FRC #3784 (Bit by Bit)
Ashley Painter is an unknown quantity at this point
Red face Re: So how many of you actually have a working minibot/deployment?
3784 has a mini bot and deployment system. We've been tweeking it some but we've had the mini bot done for weeks.
