Re: Actual Arm
We have a shoulder and elbow as well, with a gusset that reduces our required torque by about 45% and latex tubing providing 'neutral buoyancy' so that our 64:1 BB has to exert very little force to lift the arm. (I can do it easily with one finger, and I have both carpal tunnel and tendinitis!)
http://www.youtube.com/watch?v=FUNFcvnKQ-Q It doesn't backdrive at all. |
Re: Actual Arm
we made our "arm" an actual arm. it has a should joint, elbow joint, wrist joint, and a hand(claw). It works great but the shoulder joint dosent work to well
Re: Actual Arm
Ours is also an arm with three sections: the long one, the short one, and the gripper
(with Points Of Articulation #1,#2, and #3 down the arm). We seemed to have the torque issue fixed with an adjustable spring and pulley system, and then the chaining started pulling our window motors apart due to the forces involved in braking the arm during a fall . Hopefully we'll be able to resolve that issue and actually make a gripper by competition (the one I had made was much too heavy, 5.5 ibs at the end of a 4ish foot arm). |
Re: Actual Arm
Subtract 1000 from the team number of the original poster and you get 997. We also did an arm with a shoulder and an elbow. Producing enough torque was definitely an issue, especially with the weight of our gripper. A series of belts and pulleys has solved our issues.
http://www.youtube.com/watch?v=713i2...feature=autofb |
