Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 16-02-2011, 13:33
Thxe Thxe is offline
FRC #2535
Thxe is an unknown quantity at this point
Accelerometer problems
We switched to labview this year and tried to wire up the KOP accelerometer. We have tried running the example code for both SPI or I2C, however neither one works, even after triple checking the wiring. The SPI program returns -27.3 regardless of axis and movement, while the I2C program returns "ERROR <Code> -44095 occurred at The I2C sensor identification string did not match. The expected sensor is not at the address and bus specified. The sensor was expected to return "Address: 58" but instead returned "Sensor did not respond."
FRC: Invalid I2C sensor ID." We tried a different accelerometer, so it seems unlikely that both are broken. Any ideas?
Unread 16-02-2011, 23:44
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Accelerometer problems
There is an "accelerometer" example in there. Try running that before integrating it into your main robot code. If that doesn't work, you probably burned out your accelerometer or wired it wrong.
Unread 27-02-2011, 03:18
brian3795 brian3795 is offline
FRC #3795
brian3795 can only hope to improve
Ours was DOA as well, same exact error. We've pretty much given up on it.
