Go to Post The less we talk about the game hints the faster they will come. - BrendanB [more]
Unread 23-02-2011, 20:59
Solidstate89's Avatar
Solidstate89 Solidstate89 is offline
CAD Leader
AKA: AK-Fo'7
FRC #1507 (The WARLOCKS)
Solidstate89 has a spectacular aura aboutSolidstate89 has a spectacular aura about
Unknown Performance Issues with Inventor
Just to start things off, I'll say this might be a fairly long post as I'd like to get as much information that I know out there as possible. You have been warned.
OK. Well to start things off I'm a four year alumni of FIRST and this is my first year back with my old team as a CAD Mentor. Skip ahead to about two weeks ago, and everything had been going fine with Inventor with the exception that the computers provided by the school were having some real problems properly running Inventor. Now these are old machines. Pentium D's, 3GB of RAM, 32bit Windows XP and an ATi Firepro who's model I can not remember off the top of my head. Needless to say, they're barely capable of running large models, much less an entire assembly of the robot.
However we had managed to get around that issue thanks to the other mentor and myself bringing in our laptops and letting the students use those to finish the final assembly. Well on Monday of this week I decided to leave work a few hours early to check-up on the final preparations of our Robot and see what (if any) help my CAD team still needed. I come to find out that the laptop the other mentor lent to them to work the assembly on, was running Inventor so slowly that it would take literally 2 minutes for a single tick of the mouse wheel to show that it zoomed in.
Needless to say, that is completely unusable in that state. Something I hadn't seen before. To be fair, it is a consumer laptop without workstation graphics cards, but that's never stopped any laptop in the past from properly running Inventor. In a fit of desperation I relented and decided to bring in my custom built desktop from home. Now before I go on, let me just say I'm fairly well versed when it comes to computer hardware and my desktop reflects that - running quite high-end hardware. An i7 950, 6GB of RAM and two Geforce 470's in SLI. I've even got an SSD drive to boot.
I recognize the hardware components are for the most part all consumer. Especially the graphics cards. However with 1.3GB of vRAM I figured that would still be more than enough (seeing as the average workstation card usually has about 2GB of vRAM) and for the first 4-5 hours it was running about as fast as you or I would think it should. Then nearing the end of the day on Monday it began really slowing down. Not quite as bad as it was on the laptop and still leagues better than on the school computers but running far slower than the hardware should have ever permitted it.
Come Tuesday I decided to take off work and bring my desktop in to let the students work on it all day. Yesterday was incredibly slow. Nearly a minute just to apply a simple Aligned constraint (please forgive me - I forget the name of the constraint in Inventor because I work with Unigraphics for a living) of a bolt into a hole. It took nearly an hour to get 8 washers, onto 8 bolts, into 8 holes.
Now I'm not one to brag, and I certainly don't want to come off that way, but everything I've read tells me my hardware should be OVERKILL for what we need. And yet it's almost as slow as it was on the laptop they were using previously. I can not explain what is going on. I have searched through autodesk forums and found a "feature" (more like a designed bug) that records every single movement you make of the model into memory so you can use the rewind feature to go back to a previous view. Frankly it sounds useless to me, and I wouldn't care except there's no way to shut it off and even worse the only way to make Inventor free the memory being used is to restart the computer.
Now unless I've missed a forum post somewhere on this site, I haven't seen anybody else encounter this issue. I had just assumed the school computers as well as the laptop were simply underspecc'd to handle such a large assembly. However the hardware in my desktop should breeze through such trivial assemblies and models without even breaking a sweat - even if it is using consumer cards and non-Xeon/Opteron processors.
So - after this long and drawn out explanation, I ask if anyone has encountered anything like this before? Could it really just be that "rewind feature" that is causing this? Even if it does load up everything into RAM, I would think 6GB is enough (though I have seen a few people on autodesk forums recommend at least 8). I have tried uninstalling and re-installing - again to no avail. We have the professional edition on the school computers as well as the other mentor's laptop, and the student edition that came in the KOP on my desktop. 32bit and 64bit versions. Non and student editions. All encountering the same problem.
The only other commonality between them is that both the laptop and my desktop use an SSD. However on my desktop Inventor is installed on the mechanical hard drive with the files installed on the SSD as I assumed it would decrease load times. Does Inventor have some issue with SSDs and the way it caches to the page file?
I am sorry for all of these questions (especially so soon before the March 3rd deadline) however I am really at a loss here. I've even turned down the detail as far as possible for the models and we're still having issues. Short of renting out a server to do all of our modeling on, what can I do? I have never had a performance issue in all of my years this badly before. Is there some issue with the kit of parts files? Some issue with mixing them with the FTC files because they converted from Pro-E files?
ANY assistance ANYBODY can give me would be greatly, GREATLY appreciated. Help me Chief Delphi - you are my only hope.
Unread 24-02-2011, 12:47
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Unknown Performance Issues with Inventor
I'm not an Inventor expert, but take a look into "Level of Detail". I've never used it, but I think it can simplify sub-assemblies to make larger assemblies more manageable.
Here's a good article on managing large assemblies:
http://danmiles.blogs.com/files/ml11...an-miles-1.pdf
Sorry that's all I can suggest, good luck!
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 24-02-2011, 17:13
CAD Leader
AKA: AK-Fo'7
Thanks for the post. From what it sounds like, the Level of Detail acts just like Reference Sets in Unigraphics - which although we weren't using them we were suppressing unused sub assemblies and the like, so I don't think that will help matters.
I'll look through the other 30 pages or so though and see if there's anything else in there that can help me out. Thanks for the help.
Unread 24-02-2011, 17:33
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
So, try the Level of Detail, but I think you have a much bigger issue here. First of all, are you running the most up to date sevice pack of inventor (at work this seemed to fix most issues)?
Bear in mind that inventor 2011 is written for gaming cards instead of CAD graphics cards, so your hardware should be WAY more than enough.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 24-02-2011, 18:39
CAD Leader
AKA: AK-Fo'7
Yes, I downloaded all of the latest updates for Inventor during the installation process.
And yes, I agree. There is something is seriously wrong here, I'm just at a loss as to what it could possibly be (obvious with this forum post here). I'll look back into the Level of Detail, but from what I understand it's no different than just manually suppressing parts in an assembly. However there does seem to be a few tricks in there as well to reduce strain on the system.
I just don't know WHY it's producing SO much strain on such high-end hardware.
Unread 25-02-2011, 16:41
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
Team Role: CAD
kinghashbrown is an unknown quantity at this point
might be a bit of a silly question, but are you using sub assemblies?
Unread 25-02-2011, 18:05
CAD Leader
AKA: AK-Fo'7
Yes.
Why, is there an issue with Inventor and Sub Assemblies?
Unread 25-02-2011, 18:17
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
That is very interesting. Try running Inventor with only one GTX470 and see what happens. Is your i7/GTX470 overclocked?
I'm running Inventor on a 9600GT and it runs fine...
Unread 25-02-2011, 18:19
CAD Leader
AKA: AK-Fo'7
You know, as embarrassing as that is, I haven't though of running only one 470. I should go disable SLI and see what happens. That still doesn't explain why it worked fine for the first 5 hours on Monday, then began lagging.
I also haven't overclocked my i7, and I brought my 470's back to stock clock levels because I know the clock frequencies don't really give that much of a boost to 3D Modeling Programs.
And before you ask, I have tried running Inventor with Hyper Threading enabled and without. I haven't noticed a positive or negative difference with either setting.
Unread 25-02-2011, 19:51
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
I agree your hardware should be more than enough to run Inventor, but is it possible you're overdrawing still? What color is the RAM bar in the bottom right hand corner? The less full it is the better.
In order to figure out if this is a hardware or software issue, I'd check your performance monitor equivalent. If the CPU load is low, and the RAM is under 50% usage, the problem is with Inventor.
Hope this helps.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 25-02-2011, 20:31
CAD Leader
AKA: AK-Fo'7
The highest I've ever seen my memory usage spike is about 2.5GB. Which seeing as I have 6GB should still be more than enough.
I'll have to get back to you about my CPU usage though.
Unread 25-02-2011, 22:15
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
The most common problem I see in a situation like this is a conflicting assembly constraint. Impossible to diagnose without sitting in front of the machine - but I would make a substantial wager that is the problem. You might be able to isolate it by removing parts or subs one-by-one. When I sit down to find a problem like this I can usually find the suspect part or assembly fairly quickly.
I would rate almost everything I see done in Inventor as garbage. Garbage in - garbage out. There is a real problem with professional level training.
If you can pack and go the assembly and send it to me I'll take a look. (be sure to preserve file/folder structure) jmather_at_pct_dot_edu
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 25-02-2011, 22:23
CAD Leader
AKA: AK-Fo'7
There are several constraints I've seen with errors on them. And as you said, they don't seem to be uncommon. I never realized that conflicting constraints could cause such severe performance issues.
I can take a look at them myself over the weekend since I finally have some time and I'll report back my findings. I'm used to having to deal with broken and conflicting constraints with the Unigraphics models I work with at my job.
Thank you for that insight though. I really had no idea that conflicting constraints could do anything to the performance of Inventor except just make it error prone in terms of getting proper movement and proper association.
Unread 27-02-2011, 01:05
AKA: Joey Fisher
Team Role: CAD
Originally Posted by Solidstate89 View Post
Yes.
no, I was thinking that if you did not use sub assemblies, that inventor might be trying to update to many constraints which will kill performance.
Unread 27-02-2011, 09:59
ThaineP
Posts: n/a
That's a bit strange.
I run Inventor on my Dell Dimension E520 (Intel Core 2 Duo CPU, 3GB DDR2 RAM, running at 2.13GHz on Windows XP Media Center) and I can have several parts and assemblies running at once as well as a few tabs open in Firefox at the same time with no lag, but when I play Garry's Mod, if I spawn too many props (>25) it lags like crazy.
I think it's probably the computer's reaction to continued use, possibly heat?
