Go to Post I wouldn't want to replay Lunacy -- the Moon is a harsh mistress! - Richard Wallace [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #106   Spotlight this post!
Unread 26-02-2011, 18:29
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: pic: Team 148 - 2011 - Raptor
I'm curious as to why you chose to stack plates instead of just cutting a thicker plate? I can understand if it was really thick for cost purposes, like over a half an inch, but wouldn't it be easier for a 3/8 piece to just cut one from a thicker piece of metal? I suppose if you're laser cutting then thicker aluminum isn't an option on all lasers because of aluminum's reflective properties.
I've also always been curious, are your parts lasered of waterjetted?
  #107   Spotlight this post!
Unread 26-02-2011, 18:56
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally Posted by Cory View Post
John,
I'm curious how you avoid misalignment of the teeth relative to each plate after assembly. Do you bolt both plates together and then cut the teeth? Do you use pins to align them and then clamp them with bolts? is it just "good enough" that you can bolt them together without any alignment aids?
It is just "good enough."
We align the plates (using a mating gear + eyeballs) and then clamp them with c-clamps before riveting.
These are aluminum gears, and we figured they'd wear in happy.
Again -- we were surprised how well this worked. We were expecting more hassle... but... it just works.
-John
  #108   Spotlight this post!
Unread 26-02-2011, 18:57
JVN JVN is offline
@JohnVNeun
Our parts are lasered. We use 1/8" plates stacked instead of thicker plates for two main reasons:
1. The laser does have some "blow out" which will affect the tooth profile in thicker materials.
2. Our shop stocks 1/8" 6061 aluminum, so we can get it without a special order. When I'm trying to get 24 hours turns, I try not to make our shop do anything they don't normally do for production.
-John
  #109   Spotlight this post!
Unread 26-02-2011, 22:59
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Cool stuff, John!
Maybe you guys need to start up a Robowranglers R&D division to test more neat ideas like this... you can attempt all kinds of weird projects that would normally be foolish to try during a build season*. Though it sounds like your offseason work already accomplishes this.
*cough* walking robot *cough* *cough*
  #110   Spotlight this post!
Unread 27-02-2011, 11:32
LBseale's Avatar
LBseale LBseale is offline
Still love 1717
FRC #1923
LBseale will become famous soon enough
Originally Posted by JVN View Post
CG isn't reason enough?
One other reason is my hatred of chain, but mainly for CG reasons.
I would also suspect this is lighter than an equivalent low-gearbox + chain + sprocket...
Plus... c'mon... DOUBLE FOURBAR!
If you dislike chain so much, why did you choose to chain together your omni-wheels and traction wheels? From your models it looks like you have enough CAD experience to space and use timing belts. SolidWorks (at least, maybe Inventor does too) comes with a tool for calculating belt lengths that's very handy. Belts are quieter and don't need tensioning.
  #111   Spotlight this post!
Unread 27-02-2011, 11:59
JVN JVN is offline
@JohnVNeun
Maybe next year.
We dislike chains that we need to worry about. This low-load application is pretty happy the way it is.
  #112   Spotlight this post!
Unread 27-02-2011, 12:02
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
We've used laser cut gears in manipulators before when a small range of motion was desired but Ive never thought about using them in a drive application. Be sure to post up at the end of the season about any wear issues you encountered because otherwise it is a very simple solution to custom gears. I'll be sure to check them out at alamo.
  #113   Spotlight this post!
Unread 27-02-2011, 12:22
Onward through the fog.
I wonder if there is any maximum allowance of people/teams per pit. Looks like 148 is going have a crowd. Non-stop. Again.
~ Helen Keller
(1880-1968)
  #114   Spotlight this post!
Unread 27-02-2011, 13:18
Best Available Data
FRC #1778 (Chill Out!)
How do you generate the tooth profiles? Does IFI just have a piece of software that spits it out, do you do it by hand , or is there a handy SW feature that I've missed that does it for you?
  #115   Spotlight this post!
Unread 27-02-2011, 13:28
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Well 148 would be nagged about the safety issue of too much people crowding your pit.
  #116   Spotlight this post!
Unread 27-02-2011, 13:41
Actually, it's always a pleasure to notice how planning committees work to make the pits efficient and, at the same time, a showcase for teams like 148 and 118, allowing space where there is some to be had. It's also nice when rookies are placed between veteran teams or are placed in an area together where they can be accessed and helped easily by veteran teams and volunteers who will help. Teams like 148 are very aware of their draw and they work hard not to infringe on other teams' space. I've seen it on Championship level and Regional level. It's also the job of the pit volunteers to help keep things orderly and running smoothly.
~ Helen Keller
(1880-1968)
  #117   Spotlight this post!
Unread 27-02-2011, 14:00
JVN JVN is offline
@JohnVNeun
There are lots of ways to do this. Some of my favs:
1. Pull out your handy Machinist's Handbook and sketch the tooth profile by hand.
2. Buy one of those gear profile generation programs and get it to spit it out for you.
3. Download the gear from somewhere online. bostongear.com has all their gears available online.
For this year's robot we used option 3. I downloaded the gear I wanted from Boston gear, then traced over the tooth in Solidworks (eliminating splines with simple arcs, so it would import cleaner into our laser cutter's NC program). I grabbed this sketch, dropped it into a new sheetmetal part and away we went...
-John
  #118   Spotlight this post!
Unread 27-02-2011, 16:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
-John
A few more options:
  1. It's surprisingly easy to generate a real involute using equations; this and this explain how to do it in Pro/E (but any CAD software ought to be able to do the same).
  2. If you can make do with an approximation instead, either follow the second method in the link above, or get GearGen (I think it's shareware*) from here or here. (It's a DOS program, so the interface might be a little unfamiliar nowadays....) This makes a sort of segmented polyline when exporting, with arcs that (as near as I can determine) are approximate. But thanks to modern, fast computers, you can create an arbitrarily large gear and scale it down to whatever degree of precision you need—so this isn't a problem so long as your CAM software won't choke on the geometry. (Note that all of those facets will make 3-D CAD really slow to regenerate; use the equation in that case, or just approximate it for visual purposes.)
*Does anyone even use that term anymore?
  #119   Spotlight this post!
Unread 28-02-2011, 10:53
JVN JVN is offline
@JohnVNeun
After receiving a number of requests in response to this post, I decided to highlight some of the subtle parts of this year's design on my blog as part of an "Inside Raptor" series.
Another from this series which highlights the Drive Module layout.
http://blog.iamjvn.com/2011/02/insid...ve-module.html
-John
  #120   Spotlight this post!
Unread 28-02-2011, 10:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Nice drive module!
for making that strange gear for the arm lifter....you could also get the arm gear from a door window regulator from a car, and trace it onto the aluminum
