| Thread Tools |
Rating:
Display Modes |
#106
Re: pic: Team 148 - 2011 - Raptor
I'm curious as to why you chose to stack plates instead of just cutting a thicker plate? I can understand if it was really thick for cost purposes, like over a half an inch, but wouldn't it be easier for a 3/8 piece to just cut one from a thicker piece of metal? I suppose if you're laser cutting then thicker aluminum isn't an option on all lasers because of aluminum's reflective properties.
I've also always been curious, are your parts lasered of waterjetted? Last edited by sgreco : 26-02-2011 at 18:33. |
#107
We align the plates (using a mating gear + eyeballs) and then clamp them with c-clamps before riveting. These are aluminum gears, and we figured they'd wear in happy. Again -- we were surprised how well this worked. We were expecting more hassle... but... it just works. -John |
#108
1. The laser does have some "blow out" which will affect the tooth profile in thicker materials. 2. Our shop stocks 1/8" 6061 aluminum, so we can get it without a special order. When I'm trying to get 24 hours turns, I try not to make our shop do anything they don't normally do for production. -John |
#109
Cool stuff, John!
Maybe you guys need to start up a Robowranglers R&D division to test more neat ideas like this... you can attempt all kinds of weird projects that would normally be foolish to try during a build season*. Though it sounds like your offseason work already accomplishes this. ![]() *cough* walking robot *cough* *cough* Last edited by s_forbes : 27-02-2011 at 07:22. |
#110
If you dislike chain so much, why did you choose to chain together your omni-wheels and traction wheels? From your models it looks like you have enough CAD experience to space and use timing belts. SolidWorks (at least, maybe Inventor does too) comes with a tool for calculating belt lengths that's very handy. Belts are quieter and don't need tensioning.
#111
We dislike chains that we need to worry about. This low-load application is pretty happy the way it is. |
#112
We've used laser cut gears in manipulators before when a small range of motion was desired but Ive never thought about using them in a drive application. Be sure to post up at the end of the season about any wear issues you encountered because otherwise it is a very simple solution to custom gears. I'll be sure to check them out at alamo.
#113
I wonder if there is any maximum allowance of people/teams per pit. Looks like 148 is going have a crowd. Non-stop.
Again. |
#114
How do you generate the tooth profiles? Does IFI just have a piece of software that spits it out, do you do it by hand
, or is there a handy SW feature that I've missed that does it for you? |
#115
Well 148 would be nagged about the safety issue of too much people crowding your pit.
#116
Actually, it's always a pleasure to notice how planning committees work to make the pits efficient and, at the same time, a showcase for teams like 148 and 118, allowing space where there is some to be had. It's also nice when rookies are placed between veteran teams or are placed in an area together where they can be accessed and helped easily by veteran teams and volunteers who will help. Teams like 148 are very aware of their draw and they work hard not to infringe on other teams' space. I've seen it on Championship level and Regional level. It's also the job of the pit volunteers to help keep things orderly and running smoothly.
#117
1. Pull out your handy Machinist's Handbook and sketch the tooth profile by hand. 2. Buy one of those gear profile generation programs and get it to spit it out for you. 3. Download the gear from somewhere online. bostongear.com has all their gears available online. For this year's robot we used option 3. I downloaded the gear I wanted from Boston gear, then traced over the tooth in Solidworks (eliminating splines with simple arcs, so it would import cleaner into our laser cutter's NC program). I grabbed this sketch, dropped it into a new sheetmetal part and away we went... -John |
#118
*Does anyone even use that term anymore? |
#119
http://blog.iamjvn.com/2011/02/insid...ve-module.html -John |
#120
Nice drive module!
for making that strange gear for the arm lifter....you could also get the arm gear from a door window regulator from a car, and trace it onto the aluminum ![]() |
