Go to Post Be watchful of the "man this is so cool we should do it in build" as I've embarrassingly fallen victim to it so many times before, with varying results. - Aren_Hill [more]
Unread 27-02-2011, 14:01
Kives34's Avatar
Kives34 Kives34 is offline
FRC #0126
Kives34 is an unknown quantity at this point
Robot going crazy
So for the most part our robot will be going just fine until at any random point it goes crazy. We get Watchdog not fed error, no communication, no robot code and the robot will even Enable itself to boot. It keeps on jumping between all these different errors and the Emergency stop button will not work when this happens. We have tried a new cRio, new program, new wireless bridge, tethering it, new battery and even reimaging the cRio. If anyone can help that would be amazing.
Unread 27-02-2011, 15:22
Re: Robot going crazy
Some questions, maybe some answers.
The symptoms indicate there are communications from the DS to the robot.
Is the dlink buried or too near motors and causing many different forms of communications dropouts?
Since you are sometimes getting packets without voltage info -- indicating the Communication thread hasn't heard from the code and thinks none is running -- it is somewhat more likely that the CPU is highly loaded, and perhaps you have a number of higher priority threads that are starving the Communication thread to some degree. I think this would cause all of the symptoms you describe except ...
What you you mean by enables itself?
Does the DS display magically flip from Disabled to Enabled tele or auto?
Does the robot flinch?
What I/O isn't being disabled?
What language was being used?
Greg McKaskle
