Go to Post There's no better way to start your FIRST career then opening a box and getting free stuff from Andy Baker! - JosephC [more]
Unread 27-02-2011, 14:58
liam.larkin's Avatar
liam.larkin liam.larkin is offline
We will find a way or make one!!
FRC #0272 (Cyber Crusaders)
liam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to beholdliam.larkin is a splendid one to behold
Are You Planning on throwing tubes into Play
I have seen a lot of discussion about this and as my teams Coach I am really curious.
-Which teams are intending to throw out tubes into the playing field as a general strategy.
-Which teams are intending to throw out tubes only in particular situations. I.E. Opposing alliance robots cant pick from the ground or maybe only one of the three can.
Only intending to throw say the circle tube cause that one seems easiest to throw across the field.
Only start throwing in the last 1 min or something.
-Absolutly no throwing of game pieces into play except maybe just to throw right in the lane in front of the human station.
Unread 27-02-2011, 15:11
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: Are You Planning on throwing tubes into Play
We've been working with our human player on being able to throw tubes about 40ft, so that it is very close to our home zone.. The less time being spent going across the field, means more scoring.. We designed at robot that is scary fast at picking tubes of the ground.. But we can get tubes from the slot and the lane if need be..
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 27-02-2011, 15:23
davidalln's Avatar
davidalln davidalln is offline
World's Worst Coder
AKA: David Allen
FRC #2415 (The Westminster Wiredcats)
davidalln is on a distinguished road
Send a message via AIM to davidalln
I'm the human player for our team, and if you can pick up from the floor consistently, then I cannot see a reason why not to throw the tubes. Without too much practice they can be thrown 35ft, and with daily practice you should be able to get that up to 45ft+ (and if you keep going, you'll hit Robonauts HPing)
SANTOSH ANDREW DECKER RICK WYNNIE SEAN DEREK MATT
(alamo (semis), p'tree (CHAMPS!), nc (CHAMPS!), newton (quarters))
Best four years of my life. Thanks to everyone who made it happen.
Unread 27-02-2011, 15:27
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
we are planning to throw tubes, our robot is pretty quick but crossing 50+ feet of field will take too long.
Unread 27-02-2011, 15:31
Has anyone been able to simulate when 6 robots are on the field?
Unread 27-02-2011, 15:35
AKA: Nicholas
FRC #0313
Some of the week 0 competitions showed that throwing tubes was on alot of teams minds, and those tubes very close to you are important
Unread 27-02-2011, 15:53
KevinGoneNuts's Avatar
KevinGoneNuts KevinGoneNuts is offline
AKA: Kevin
FRC #0675 (Tech High Robotics)
KevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud of
Our team is still debating this topic. Our Human player(s) can throw far, and our robot can very quickly pick tubes up of the ground.
The only thing we see wrong with it is that we may possibly aiding the opposing alliance.
I think we may just throw the tubes into play, but we will definatly consult with our alliance first.
Unread 27-02-2011, 15:57
Tyler Hicks's Avatar
Tyler Hicks Tyler Hicks is offline
NC Gears
FRC #1918 (NC Gears)
Tyler Hicks has a spectacular aura aboutTyler Hicks has a spectacular aura aboutTyler Hicks has a spectacular aura about
If both alliances are throwing them, then it will require less robots crossing the field. However, a new position to play might be "tube stealer" instead of "tube runner". It's going to take a few matches to see the best strategy.
2010
2011
2006-Pres.
Unread 27-02-2011, 17:02
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by Tyler Hicks View Post
If both alliances are throwing them, the it will require less robots crossing the field. However, a new position to play might be "tube stealer" instead of "tube runner". It's going to take a matches to see the best strategy.
I've been wondering about this too, and thinking that a 'starvation strategy' may work against an alliance that throws their tubes out there 'willy nilly'.
___________________
- Tennyson, Ulysses
Unread 27-02-2011, 17:05
Chris is me's Avatar
AKA: Pinecone
I want to say no...
But what I fear is going to happen is that enough teams will start throwing tubes that the other side has little choice but to follow suit, flooding the field and making the game a lot less interesting.
However, the current plan remains don't throw tubes. Remember ball starvation in 2009? It's the exact same thing.
Unread 27-02-2011, 17:08
Chris is me
I agree that is where I am right now. Starve the other team and control the flow
Unread 27-02-2011, 17:09
Eric222 Eric222 is offline
FRC #0222 (Tigertrons)
Eric222 is an unknown quantity at this point
I find it to be a risky strategy, but I guess it mostly depends on the consistency of your human player.
Unread 27-02-2011, 17:11
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Everyone claims they can pick up off the floor and that's fine n dandy.
The question isn't whether or not you can pick tubes off the floor. It's how quick you and your partners can get those tubes off the floor compared to the others guys behind the opposite glass can. Teams need to be dead set honest with themselves on this because if they overestimate their capabilities and underestimate their opponents capabilities they could be setting themselves up for a serious butt kicking.
That means scouting is really important this year. Not just to determine who you want on you alliance but what the other robot can or cannot do so you can do that voodoo that you do so well.
Unread 27-02-2011, 17:20
AKA: Nicholas
FRC #0313
I think that by the end of week one we will see that running to get tubes will be to time consuming and those teams that choose to go that rout will be the ones that fall... more often than not...
Unread 27-02-2011, 17:44
Excellent point. This is always a problem though teams claiming they can do things they cant. I always try to be as diplomatic as possible and tell them to stop kidding themselves. I find it is much easier when it is an adult coach not saying I have not meet some killer student coaches. They just are more honest with themselves
