Go to Post in FIRST it's not just about where you finish in the standings but the intangible of inspiration where there is no true or immediate forum of measurement. - Koko Ed [more]
Unread 27-02-2011, 20:34
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
Arm swings when turning, how to brace it?
Or arm is made of a single four foot aluminum c-channel with a fabricated 8020 bracket at the top to hold our window motors for the shoulder joint. the next stage is another three foot c-channel with the gripper on the end. we noticed in the little practice time we had that the channel tends to twist when we turn. Does anyone know of a way to brace the channel so that it won't twist? there are some pictures on the portal of our robot from last monday (team 3329) if that helps anyone. Thanks!
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 27-02-2011, 20:45
J93Wagner J93Wagner is offline
Where'd all the time go?
AKA: Jonathan Wagner
no team (Formerly N.E.W. Apple Corps)
J93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to beholdJ93Wagner is a splendid one to behold
Re: Arm swings when turning, how to brace it?
Twist? In what way? Without knowing more about the problem, I can't help you. Sorry.
My personal favorite quote: "There is nothing better than being proud of the things you love." -Sean "Day[9]" Plott
Unread 27-02-2011, 20:51
HarveyAce's Avatar
FRC #3329 (CAMBots)
the c-channel literally twists. like your ringing out a towel, just not as dramatic. like someone is holding the ends and trying to make a metallic twizzler out of it. hasn't had any damage yet, my concern is just that we don't want to enter a match like that.
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
a c channel or angle will always be easy to twist, if you could replace it with some kind of tube, round or square etc, it would be much more rigid.
2016 Central Illinois Winner. Curie Division finalist
Unread 27-02-2011, 21:06
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
You may try bolting another C-channel over the open side of your existing C-channel. I assume your using the AndyMark C-channel from the kit of parts. There is another C-channel that fits over the AndyMark - maybe from IFI - someone can probably confirm this. This isn't an ideal fix but it may be easier than replacing the entire arm section.
Unread 27-02-2011, 21:15
HarveyAce's Avatar
FRC #3329 (CAMBots)
Actually we are using donated c-channel from the Trident Refit Facility here on Kings Bay Naval Base. They fabricated the channel from Aluminum sheet, as that is all they could do. other channel could be hard to fit into the grove as we have various screw and bolts going through the arm...
Unread 27-02-2011, 21:25
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
If its not too complicated to do, switching to a tube round or square is the best option. C-channels are just by design quite flexy like you have seen.
Unread 27-02-2011, 21:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
if you post some pictures of the robot, and the parts that are twisting, we might be able to help you figure something out. Otherwise we're just guessing..and that doesn't help you much
Unread 27-02-2011, 21:37
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Best way to strengthen a channel is to box it in. One way is to bolt on another C as sugested or you could weld a plate to the open end of the C.
Unread 27-02-2011, 23:27
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Ill say it again, square tubing 1/16in thick, its light, durable, and some-what cheap. If you don't have a local hardware store that has any you can get some from McMasters for under 10$ and it will ship in 18-24hrs.
Here's the URL for it http://www.mcmaster.com/#tubing/=b829jk
Unread 28-02-2011, 00:12
MrForbes's Avatar
AKA: Jim
I live in a small city, there are at least 4 local stores that sell 1x1x1/16" wall aluminum square tubing. But I don't know if it would fit onto your robot easily. Also, round tubes such as ABS sewer pipe will not twist, and are readily available in several sizes (ID from 1.5" to 4" is very common), and might be more easily adapted.
Unread 28-02-2011, 09:32
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Squirrel, what local stores sell 1x1x1/16 sq al tube? We use a lot of it and always have to special order it from a local metals supplier.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 28-02-2011, 09:40
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
We managed to strengthen a bit of our cbase from twisting the way you mention by fitting in some 1010 8020 (1" x 1" extruded aluminum) into the channels and bolting it down. Maybe you can try that with some square tubing. We also used the 8020 in the cbase for mounting purposes but for just strengthening i'm sure just square tubing will work alright.
Unread 28-02-2011, 10:35
MrForbes's Avatar
AKA: Jim
Bruce
Ace, Sutherland's, Lowe's, and Home Depot. Although I have to double check Lowe's, as I didn't buy it there this year.
Unread 28-02-2011, 10:45
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I can attest that Lowe's carries it.
So does Menard's.
Hi!
