Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 25-02-2011, 21:56
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Importance of Autonomous
How important do you think Autonomous will be this year?
Unread 25-02-2011, 21:59
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: Importance of Autonomous
Very.
If you can't consistently score high on auto, don't expect to be an elite, or even a very good, team.
Unread 25-02-2011, 22:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Depends where you're playing....
Unread 25-02-2011, 22:12
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Personally I think even autonomous has been important although some will argue with me on that!
On the low row not so much since it only give you an extra point but on the mid and top it will give you an edge.
1058 PVC Pirates 2016 - xxxx
Unread 25-02-2011, 22:18
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Autonomous could multiply your points by a bit, especially if your alliance does double logo top row with 3 uber-tubes up top.
Unread 25-02-2011, 22:26
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Autonomous will be huge because scoring one uber-tube high in autonomous can turn a logo worth 18 points into a logo worth 30 points (6 from auto and 6 from the multipliers), the same as a winning mini-bot. If you get two teams each scoring an ubertube on one high logo, then you turn a logo worth 18 into a logo worth 42, and that with only 3 telop tubes and 5 tubes total. Without any ubertubes it would take 2 top row logos plus a 3 random tubes in the middle to match this score. That's 9 tubes that need to be placed in telop in comparison to 3. Auto gives a team huge advantage in the tube section, giving them a little bit more leeway in the minibot race.
www.sharkattack744.com
Unread 26-02-2011, 00:37
pfreivald's Avatar
AKA: Patrick Freivald
Consider the fact that two logos on the top row are worth 36 points, but with three ubertubes those same two logos are worth 54 points PLUS the 18 points for autonomous scoring = 72 points...
Three ubertubes scored (assuming logos go on top of them) edges out the fastest minibot by six points.
Conclusion based on this simplistic analysis: Autonomous will be huge.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 26-02-2011, 01:02
MrForbes's Avatar
AKA: Jim
Alternate conclusion based on how many robots I usually see at the AZ regional being capable of scoring in autonomous: Autonomous will be insignificant at many regionals
Unread 26-02-2011, 07:57
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Our team thought enough about autonomous that we were able to do this very consistently 1 week before bagging.
http://www.youtube.com/watch?v=SEYYXmcHgyQ
With that being said I agree with Squirrel: It all depends on where you're playing.
Expanding on that thought I'll add that it also depends on which week you're playing. I predict autonomous activity to get much better in subsequent Regionals. Just like in years past.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 26-02-2011, 08:02
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Less robots able to score in autonomous makes it a bigger advantage for those that can IMO.
Unread 26-02-2011, 09:33
GaryVoshol's Avatar
Cogito ergo arbitro
Autonomous won't determine winners of matches nearly as much as it did in Aim High. Neither are the rewards so trivial as to make hardly any difference, as was the case in Triple Play. This year it's somewhere in between. An autonomous score gives the alliance an advantage, but it is not an advantage that is insurmountable. I think it's a good balance this year.
(since 2004)
Unread 28-02-2011, 10:17
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Now that I run trough the numbers it seems like the autonomus is a good point boost but wouldn't be enough to upstage something as big as the minibots, but still valuable. Assuming that there are two strong alliances that will all hang two logos each on the top row ubertubes are worth 12 points. From what I've seen in week 0 matches I think strong alliances can score an ubertube a (top) rack easily enough but to score 2 on the same top rack was hard. That 12 points could really make a difference with two closely matched alliances.
By the numbers an extra 12 points couldn't change the outcome of a minibot race, however an upertube under a top row logo is equal to an entire middle row logo. The ubertube is one tube that essentially holds the value of three tubes plus the time to score them minus the ability to score them on the top row.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 28-02-2011, 10:41
Jared Russell's Avatar
Taking a year (mostly) off
Assuming that you can hang a logo on top of it, each ubertube on the top row is worth 12 points (6 for the ubertube itself, 6 for doubling the value of the tube that covers it which then gets re-doubled for being part of a logo).
The minibot is worth 30, 20, 15, or 10 points.
Do the math (assume for a moment that each alliance scores the same number of tubes during the teleoperated period, and that each ubertube is covered with a logo):
#Ubertubes - MinibotFinish1 - MinibotFinish2 - TotalBonusPoints
0 - 1st - 2nd - 50
0 - 1st - 3rd - 45
0 - 1st - 4th - 40
0 - 1st - DNF - 30
0 - 2nd - 3rd - 35
0 - 2nd - 4th - 30
0 - 2nd - DNF - 20
0 - 3rd - 4th - 25
0 - 3rd - DNF - 15
0 - DNF - DNF - 0
1 - 1st - 2nd - 62
1 - 1st - 3rd - 57
1 - 1st - 4th - 52
1 - 1st - DNF - 42
1 - 2nd - 3rd - 47
1 - 2nd - 4th - 42
1 - 2nd - DNF - 32
1 - 3rd - 4th - 37
1 - 3rd - DNF - 27
1 - DNF - DNF - 12
2 - 1st - 2nd - 74
2 - 1st - 3rd - 69
2 - 1st - 4th - 64
2 - 1st - DNF - 54
2 - 2nd - 3rd - 59
2 - 2nd - 4th - 54
2 - 2nd - DNF - 44
2 - 3rd - 4th - 49
2 - 3rd - DNF - 39
2 - DNF - DNF - 24
3 - 1st - 2nd - 86
3 - 1st - 3rd - 81
3 - 1st - 4th - 76
3 - 1st - DNF - 66
3 - 2nd - 3rd - 71
3 - 2nd - 4th - 66
3 - 2nd - DNF - 56
3 - 3rd - 4th - 61
3 - 3rd - DNF - 51
3 - DNF - DNF - 36
Now analyze until your heart's content. If your opponent has the two fastest minibots in the world, but doesn't score in autonomous mode, then an alliance that scores 3 ubertubes merely needs to get one minibot up the pole in 10 seconds to gain the edge in "bonus points".
I also want to make a prediction: all season, no alliance will ever lose a match if they place 1st and 2nd in the minibot race and score all 3 ubertubes on the top row (ignoring penalties and red cards).
Unread 14-03-2011, 10:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Autonomy is a public statement. It shows dominance over the other team by saying that they have a very accurate and intuitive robot. The other alliance we were playing against all simultaneously scored the ubertube on the top peg during autonomous period. I must say, we were freaking out. It is a public statement. It is psychological "warfare". If you see 3 teams score simultaneously, you know it would be a tough alliance to beat.
Unread 14-03-2011, 10:59
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
This is why we do the math...
