Go to Post You will find the LRI, Head Ref, & FTA don't have a lot of time for popcorn during a competition. :) - FrankJ [more]
Unread 09-02-2011, 12:12
Macsli1 Macsli1 is offline
Uber Tuber
AKA: Matt C.
FRC #0569
Macsli1 is an unknown quantity at this point
Only Load Driver Station on Secondary Laptop in "Driver" User Account
I noticed that on the Classmates, when the driver account is loaded, the only program to run is the driver station program in full screen.
We installed the driver station on a separate laptop and it works properly. However when the driver account loads the driver station does not start up as the only program to run in full screen mode.
I added the driver station into the START -> All Programs -> Startup folder to solve the start up issue.
I was wondering if there is a start up script available for a non classmate laptops driver account so that it loads in the same manner as the classmates... I.E.: full screen, the only program to load, no start bar.
FYI: We are running win7 using LabVIEW.
Unread 11-02-2011, 01:04
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Only Load Driver Station on Secondary Laptop in "Driver" User Account
It's likely that the other laptop has a different screen size/resolution than the tiny Classmate screen. The Driver Station and Dashboard will fill less of the screen and probably won't tile and remove the borders like it does on the Classmate.
You are actually seeing two programs, the Driver Station and the Dashboard. Driver Station loads the Dashboard and they neatly tile together and fill the screen on the Classmates.
You can edit the Dashboard and customize it as you like. If you open it and look at the code it's fairly easy to see how the screen attributes are set when it detects that it is using the "Driver" account.
However, since the Driver Station is supplied from FIRST and can't be altered, you can't do much to it, even change the size on the screen.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 11-02-2011, 02:28
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
You can configure the driver station to be the shell for that account (like the classmate does).
Unread 26-02-2011, 12:58
555Robotics 555Robotics is offline
FRC #0555
555Robotics is an unknown quantity at this point
Actually, in somewhat of a reverse question, how would you change the shell for the Driver account to something else (and then have the Driver Station startup elsewhere)?
Unread 27-02-2011, 18:11
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I load task manager (Ctrl+Shift+Esc) and open Explorer as a new task. That gives you the Windows Taskbar. I'm not sure how to make that permanant.
Unread 28-02-2011, 15:26
Clayton Yocom's Avatar
Clayton Yocom Clayton Yocom is offline
Programming Mentor
FRC #0027 (RUSH)
Clayton Yocom will become famous soon enoughClayton Yocom will become famous soon enough
Send a message via AIM to Clayton Yocom Send a message via MSN to Clayton Yocom Send a message via Yahoo to Clayton Yocom
Originally Posted by cgmv123 View Post
...That gives you the Windows Taskbar. I'm not sure how to make that permanant.
You don't. The point is to use the developer account when you need access to anything other than the driver station and to use the driver account only for driving. You can use explorer for mundane tasks but I wouldn't recommend using driver for anything more than that, because you start impacting performance on the DS.
Unread 01-03-2011, 20:47
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
How? Google has failed me thus far.
Oh that explains things
Unread 01-03-2011, 21:08
I found this post in under ten seconds.
