Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 28-02-2011, 15:25
3286's Avatar
3286 3286 is offline
AKA: mike s
FRC #3286 (the Rock-It surgeons)
3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of
Compressor not autostarting
We are having problems auto starting the compressor. Does anybody any snippet of code that can enable that.
Unread 28-02-2011, 15:39
Re: Compressor not autostarting
What do you not understand about the compressor example?
(That's not intended as a put-down or as sarcasm. It's a real question, intended to find out more about what sort of help you need, and at what level of detail.)
Unread 28-02-2011, 15:51
3286's Avatar
AKA: mike s
Well we followed the instructions that came with the build kit and it activated the compressor but at the push of a button. We want to activate it automatically.
Unread 28-02-2011, 16:25
What instructions are you referring to?
The quick answer is to place a Compressor Open function in Begin.vi, and wire its device reference output to a Compressor Start function. That'll do it.
You really ought to follow through and store the reference using a Compressor Refnum Set, so you can do a Refnum Get and a Close in the Finish.vi when the program completes. If you leave that step out, it's no big deal, since in normal operation the code never actually does complete.
Unread 28-02-2011, 16:48
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If you hold the button for the compressor down, does it automatically shut off when the storage pressure gets to 110 psi (or so) on the gauge? If not, then the compressor module will not run the compressor since it doesn't detect the pressure sensor. An inspector will check this at competition, so be sure to test it yourself as well.
GitHub
