Go to Post Darn IFI and AndyMark for making quality products! :) - Gabe [more]
Unread 28-02-2011, 15:19
Skragnoth Skragnoth is offline
AKA: Clayton
FRC #0133 (BERT)
Skragnoth has a spectacular aura aboutSkragnoth has a spectacular aura about
Camera Output Overlay
Does anyone know how to enable a vertical line overlay down the center of the camera output on the default driver station dashboard?
Our team is using the Axis camera to assist the driver in manually lining up with the deployment tower.
I suppose if all else fails, we can tape a line down the middle of the output on our classmate display.
Also, we are programming in java.
Unread 28-02-2011, 15:39
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Camera Output Overlay
you can't do it with the default driver station, but you can:
modify it (its written in LabVIEW)
write your own
use ZomB
if you use ZomB, drag a camera view on. Then create an image with the overlay you want (leave background transparent). Drag an image control on, and set the source to the image. Reposition it on top of the camera view. Save and deploy! you could also put the image as the background brush of an alert control and make it disappear/appear at will.
Watchdog.Kill();
Unread 28-02-2011, 15:46
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
If you want to modify the default dashboard, it's not that hard.
Just create a Dashboard project in LabVIEW, and it will give you all of the code. You can find where it gets the image, and use the Overlay VI's to create an overlay rectangle (you could also use a line, but lines are 1px wide and hard to see).
You can't do it on the cRio because the image is never stored in a form you can work with before it is sent out to the dashboard. It is acquired from the camera (raw), and sent off to the dashboard, and then decoded into an actual image. The dashboard gets the raw data, and decodes it for its own use.
Kettering Motorsports
Unread 14-03-2011, 10:32
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
I have heard of some Java teams writing their own Dashboard with JFrame's. So if you're capable of that, go for it!
I'm not too experienced in LabVIEW, but I am going to try making my own when our second cRIO gets here (which will hopefully be soon!) LabVIEW can't be too hard to learn, can it?
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 14-03-2011, 10:39
LabVIEW is very easy to learn. But watch out: the more you think you know about programming, the harder it can be. Be ready to forget everything first, and accept the dataflow programming paradigm as its own thing.
