Go to Post Duct tape can fix everything except relationships with other people. - dixonij [more]
Unread 28-02-2011, 08:35
Electrical Engineer
Rookie Year: 1995
Re: Interpertation on Bumpers: Do the bumpers need to display the team numbers?
Originally Posted by kws4000 View Post
For the past, what, 3 years now, we have used plexi for the electrical box, becouse it doesn't bend under load. Never had a problem. Asides from that, true, lexan is much more resilient under shock.
Back in the 90's, Plexiglass was explicitly forbidden on the robot by rule. When the ban was lifted, I bought a small sheet at the HD for an electrical panel. When it shattered during routine tooling, we went back to polycarb and never looked back.
No team I have ever mentored has ever had Plexiglass on their robot.
To the original poster: If the rules don't persuade you, note this quote from this document:
Team number displayed with 4” tall x ¾” stroke, on the bumpers, 4 locations at approximately 90 deg spacing, in contrasting color or background.<R9>
Without the team number on the bumpers as specified, you will not pass inspection.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 28-02-2011, 08:55
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Let this be your guide... I predict 50% of the robots on the field will have an arm for scoring at least the center rows. That means at least one robot on the opposite alliance in every match will have extensions beyond their frame perimeter. Those arms will reach over six feet and can contact your plastic signage.
It's more than just that. Simple vibrations will crack the acrylic where the bolts go through to mount it to your backing. Acrylic is not acceptable for a FIRST robot under any circumstances. If I won't use it in my computer for waterblock tops (where there is negligible vibrations and no movement), you definitely shouldn't ever use it on a FIRST robot.
Theres a few companies (Thermaltake) that used to make waterblocks with acrylic tops and meager 10°C changes to the acrylic along with the pressure the barbs put onto the threadings to maintain a watertight seal caused many of these blocks to crack and leak water over the users video cards and motherboards.
Unread 28-02-2011, 11:10
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
I find it interesting that this post has turned into a post on acrylic vs polycarbonate.
With students, I normally do the "vise test" . .
Give a student (with safety glasses of course) a small piece of polycarb and tell them to smack it against the vise.
Then give them a piece of acrylic and tell them to do the same thing.
That'll teach em.
(and yes, you need to put your numbers on your bumpers . . silver Sharpie works GREAT!
http://www.amazon.com/Sharpie-MARKER.../dp/B001GXFNYI)
Unread 28-02-2011, 12:58
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We used plexi (acrylic) to make a mounting bracket for our C-Rio, since we have access to a laser cutter, which can't cut polycarb. It allowed us to precisely "drill" the holes for the bottom of the C-Rio, and mount it in a way that it won't crack.
But then we took it off for weight and made a smaller bracket by hand out of polycarb
Unread 28-02-2011, 13:00
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Is there any difference between "plexiglass" and "acrylic"? I have seen stuff marketed as "plexiglass" that was very brittle and virtually impossible to drill holes in without cracking. We have had decent success with "acrylic" sheet (as marketed by Ace Hardware), for non-structural, flat panels that are well supported along the edges. It drills fairly well, and is quite flexible, but will break before it bends. In 2009 we had 3 large panels (30" x 44") of the stuff and they held up very well despite impacts that bent the supporting structure (yeah, I know - that was Lunacy and there weren't arms and impacts weren't like they are on carpet).
We have three small, non-structural panels of it on the robot this year (because I had a tightwad moment and it was in stock), and we are taking bets about how long it holds up. Will replace any broken sections with Lexan, though.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 28-02-2011, 13:10
Matt C's Avatar
FRC #1468 (J-Birds)
I got my money on 2nd practice round.
Unread 28-02-2011, 14:06
We cut poly on our laser cutter all the time. We have even used it for wheels in the distant past also cut by the laser. It does require some serious deburring operations and the smell takes a while to get used to.
Unread 28-02-2011, 15:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I thought I've read polycarb is dangerous to laser cut, due to toxic gasses produced? Can anyone confirm or deny?
Unread 28-02-2011, 15:58
The laser bed we use has fume removal built in.
Unread 28-02-2011, 15:59
Racer26 Racer26 is offline
1075 used plexiglas on our 2003 electrical board. We had to remake that board several times, and the competition robot had chunks missing from where it had cracked and we couldn't fix it.
Never again have we used it. We switched to some super-thin aluminum sheeting (in the neighborhood of 0.008", IIRC) for our electrical panels since then.
Unread 28-02-2011, 17:02
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
??? Aluminum foil???
Also, why not use polycarb? You won't short stuff out by drilling into it, and you can mount your crio directly to the polycarbonate which can then be directly attached to the frame without any additional insulation.
Unread 28-02-2011, 17:26
Matt C's Avatar
FRC #1468 (J-Birds)
Most teams I've worked with use plywood to mount electonics . . .
Unread 28-02-2011, 20:15
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
There is a drill for plastics that has a steeper angle at the tip. I have no recommendation but you could try here for at least the claim of flawless holes in plastics.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 28-02-2011, 20:21
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Polycarbonate is what my team uses every year now. It worked fine for us and saves plenty of weight.
Unread 28-02-2011, 20:37
Chris is me's Avatar
AKA: Pinecone
A small, benchtop laser cutter found in many schools would be unable to do this - only huge ones in plastic shops.
