#121
Re: pic: Team 148 - 2011 - Raptor
Why did you decide to ditch the drop down perpendicular omni wheel this year? I would think strafing would be the only upside to this whole switching drivetrain
#122
if im mistaken and it does not have a 5th omni to go side to side... here it shows the robot "auto magically" lining up to the pole. Last edited by hurtzmyhead : 28-02-2011 at 13:32. |
#123
There are plenty of advantages to this system. I really like this system and hope to develop something similar in the off-season. -Tim |
#124
I really like how the traction wheels are geared differently than the omni wheels. Simpler than shifting indeed! |
#125
@ Chris, you do bring bring up a valid point. However, the omni-wheels will allow for a more maneuverable robot. This is what I was trying to say. Thanks for catching that
#126
I can imagine that the all-omni wheel drivetrain would create a nice "drift" effect when turning around during high-speed motion, a maneuver that can be seen at about 1:44 in their video. I can imagine that this will come in handy, due to the "back and forth" nature of driving in this game, and that this may have actually been hampered by the kicker wheel.
CAD drawings that flash by all feature a kicker wheel, as well as many practice bot pictures. But all footage of the final robot seems to place the battery in the center of the robot, in place of the mass of sheet metal that (presumably) supported the sideways wheel. Also, John mentions a major change to subsystem 1 (the drivetrain) here. Coincidence? Or iterative design? Last edited by Joe G. : 28-02-2011 at 14:19. |
#127
The original drivetrain was a full Nonadrive system, but we ended up removing the sideways wheels around Day 31 (see the blog post linked above). After a week of practice we decided it wasn't necessary. In my mind, all our work and testing since that point has confirmed we made the right decision. When we removed the middle wheel our original plan was to swap out the 4 primary omni wheels with 6" traction wheels, however... well... we were impressed with what our driver Connor can do with it. We call this configuration "Butterfly Drive." Which is a joke in reference to how this robot can be pushed sideways while on all omni wheels (obviously when we drop the traction wheels she stops floating like a butterfly and stings like a... you know.) I don't think all of it's virtues are readily apparent. I assure you there are more reasons to do an articulating drive than moving sideways. Though I realize most other teams may not value the same things we do, and as such may not make the same tradeoffs we did. We love "traction mode" and it's virtues in autonomous and driver control. We love the simplicity and modularity of this module design. We love how the drivetrain performs on all omni-wheels (super efficient geartrain + 4 omni wheels = smooth like butter). We're very happy with what we ended up with... -John |
#128
I remember way back to 2003, team 980 had a similar drive system in which they raised or lowered two different sets of wheels to essentially have two different final drive speeds/ratios.
#129
Team 810 did the same thing in 2002, from what I remember.
#130
While I think its cool shifting wheels instead of shifting gears, I don't really see how it is simpler at all. A transmission is quite compact and requires a small amount of force to shift versus needing enough force to lift the robot to drop down the traction wheels. The only potential benefit I see of this system without the perpendicular omni wheel is the ability to change the center of rotation although the benefit of that wouldn't necessarily be worth the added weight of the system.
JVN given that you ended up taking out the 5th omni wheel would you stick with this drive if you could do it over or go with a more conventional 6 or 8wd with shifting transmission? |
#131
Utlizing COTS gearboxes and wheels, a team with a drill press (or even a hand drill), could make such a drivetrain. |
#132
By the way, the above blog post refers to large performance gains with the removal of the 5th wheel. What are those gains? Last edited by Chris is me : 28-02-2011 at 17:39. |
#133
Unless, of course, you've put the CIM on the module... like 148 does... Last edited by Chris is me : 28-02-2011 at 19:07. |
#135
This layout comes with its own set of challenges and constraints, but we like it a lot more. -John |
