Go to Post Awesome doesn't even scratch the surface here folks. - DonRotolo [more]
Unread 28-02-2011, 17:30
Roboman01 Roboman01 is offline
AKA: Bradley Matheus
FRC #0687 (Nerd Herd)
Roboman01 is an unknown quantity at this point
Re: Solution: Variable position of cylinder in compliance with <R74>
Originally Posted by PAR_WIG1350 View Post
Make no mistake, I love pneumatics and prefer them over motors for some applications. However, for variable positioning applications, I prefer motors.
Also, while it is possible to use only one encoder while using my system, I must admit that it is more prudent to use two. That being said, I have already admitted that for this application you solution would be a better fit. However, for applications with a more predictable load, my system becomes more competitive.
Okay, that makes sense. I admit, your design is a rather clever workaround to the problem presented in <R74>. I can see how, with the correct setup (possibly an electronic regulator), your system could be superior to mine, in terms of weight savings.
