Go to Post The greatest reward you can give your mentors is to become one. - Ed Sparks [more]
Unread 22-02-2011, 17:53
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
Camera Issue with robot
When ever I plug the Camera into the c-rio An error and enable the robot, we would get a live feed from the camera for like 4 seconds and then for some reason the robot would disconnect from the Driverstation and an error would show up on Windriver saying:
Target Exception:
VxWorks6x_10.3.69.2: Exception in Kernal Task FRC_paramTask:0x231b5b0
at pc=0x198F84
Vector 0x300 : Data Access addr=0x6D5FE50E status=0x3E8
The System has been stopped. Do you want to attach the debugger now?
do any one know how to fix this?
Unread 22-02-2011, 22:58
Re: Camera Issue with robot
Is that happening with an Axis 206 camera, or the newer M1011?
Unread 22-02-2011, 23:05
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Did you free the memory first? I just want to make sure...
And yes! attach the debugger. DO you not realize how important of a tool a debugger is? Hence the name DEbugger
Unread 23-02-2011, 11:31
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
Yes, we are using the new M1011 camera, and I have clicked yes to attach the debugger but still nothing, it would not connect back to the driverstation at all. I have tried using the 2011 camera but when its plugged in, and we enable the robot we have no control while we are getting the live feed as if the robot was disabled.
Unread 23-02-2011, 13:03
Originally Posted by krudeboy51 View Post
...using the new M1011 camera,...
I don't know if it has anything to do with your problem, but there is apparently a software issue with the provided software and the M1011. See this thread for possible hints on fixing it.
I use neither C++ nor the M1011, so I can't verify anything one way or the other.
Unread 28-02-2011, 16:48
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
I was not any help at all I still have the same problems, I put up a post last week but no reply and the step that the guy put up to change the file are not clear
Unread 28-02-2011, 19:20
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Does WPILib have exception handling?
That might be helpful...
JabbaScript
Unread 28-02-2011, 19:28
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
what is that?
Unread 28-02-2011, 23:13
masoug's Avatar
Food Consumer
FRC #0114
what is that?
http://www.cplusplus.com/doc/tutorial/exceptions/
JabbaScript
Unread 02-03-2011, 15:49
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
yea, im confused! but wasnt the new update supposed to fix this problem??
Unread 02-03-2011, 16:07
The tracker is still open, http://firstforge.wpi.edu/sf/go/artf1330. It also wasn't listed as being fixed in the last release. http://firstforge.wpi.edu/sf/frs/do/...e_for_2011_f_1
What makes you think the latest update was supposed to fix the problem?
Unread 02-03-2011, 17:56
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
because the proposed vision files were uploaded to firstforge before the update, but even if, there are no instuctions on how to insert the proposed files into the wpi library so I can use it as a reference instead of the one that causes this problem that is now in the wpi library. I have tried the update on that link " http://firstforge.wpi.edu/sf/frs/do/...e_for_2011_f_1 " but I still gives a live feed for about 5-6 seconds and then the robot disconnects
Unread 02-03-2011, 18:14
I see you've already found this thread which has instructions: http://www.chiefdelphi.com/forums/sh...rebuild+wpilib If the instructions in that thread were not clear, asking specific questions in that thread would be best.
