Go to Post And THAT is why they have safety manuals. - Eria4044 [more]
Unread 28-02-2011, 22:18
jkudo jkudo is offline
FRC #2168
jkudo is an unknown quantity at this point
Re: paper: Aluminum Falcons (FRC2168) 2011 Scouting System Ver 1.1
Hi guys,
Thanks for all the positive feedback so far - I hope the scouting system works well for all of you.
Originally Posted by RookieWookiez View Post
Wow, awesome looking scouting sheet! We're having a bit of difficulties here with the scout input data. Everytime we try to add in an entry, we get "Run-time error '1004'" and doesn't add in the data for us. It says its an application or object-defined error. We're not sure if it's our computer that we're using or if there is some sort of error with the coding.
I know you said you figured out the error but can you go into more detail why that error was happening or how? I'd like to know if its something I can fix for future users.
Originally Posted by Carter12s View Post
It is not super important, but has anyone found a workaround for this, or do I just need to get some more computers with excel 2003?
I believe the excel object structure and thus the coding for VBA for excel has changed between excel 2003 and excel 2007. I coded everything in excel 2003 so I know it will work for that. I can't guarantee results for any other version of excel and I probably won't get around to figuring out what has changed between the two versions to upload a 2007+ compatible scouting file.
Regarding the password for the code and the sheets, I'm pretty reluctant to reveal it because of how sloppy/non-intuitive the code is in terms of readability. Maybe if I get around to commenting at some point...?
Unread 28-02-2011, 23:37
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
The chef never likes to admit wiping his hands on his apron. We can forgive quite a bit when the result is solid and stable. Did you code with glasses on?
Thanks anyway. I might even be able to get my team members more interested in scouting because of this system. Stranger things have happened.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
