Go to Post Hey, I'm not my dad, I dont know anything! - Lil' Lavery [more]
Unread 28-02-2011, 16:10
Team 2524 Team 2524 is offline
FRC #2524
Team 2524 is an unknown quantity at this point
Does the I/O section of the FRC Driver Station need to work?
We're having difficulties running our code and i really can't figure out the problem. THe jaguar is showing a fault condition and I'm really unsure what needs to be green on the driver station. Post pics plz??
Unread 28-02-2011, 23:49
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Does the I/O section of the FRC Driver Station need to work?
The I/O tab is only used if you have the Cypress board attached. The Cypress is the best/easiest way to use non-joysticks to control the robot.
A fault condition on the jaguars means over current (stalling), over temperature, under voltage (from battery) or limit switches (make sure yer jumpers are in).
Unread 01-03-2011, 08:29
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Here's my method of programing problem solving.
  1. Run trough your code with a fine tooth comb while electrical checks their wiring.
  2. When electrical tell you it's good check your code again.
  3. When you are sure beyond any doubt that your code is correct check electrical's work yourself.
  4. Fix the wiring.
If at any point you find a code error quickly fix it and blame electrical for not giving you enough time to work on the robot.
Not the prettiest way of doing things but it gets the job done.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 01-03-2011, 09:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The Logitech gamepad is probably better/easier for making non-joystick controls, but the Cypress is great for adding custom switches and stuff.
We did both.
