How would you suggest adding additional spikes, then? We have the same problem as 469 does. When we got our control box, it was wired for four spikes. Between the 4 spikes, 4 victors, compressor relay, and the Robot Controller, there are no more spots left on our posititve fuse block. The negative block is fine (you can screw on multiple ring connectors to a single screw) but we have no more space for fuses for the three Spikes added this year. Is there a way to put all 7 on, or are we limited to 4 because of the "no modification" rule.
Jeff Waegelin
