Go to Post I knew you guys were really smokin' at Championships. I just didn't realize how much! - Mark McLeod [more]
Unread 01-03-2011, 15:50
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Grab Tube on the Run!
Here is a video showing our manipulator grabbing a tube on the run.
http://www.youtube.com/watch?v=IRw_t9pXI6s
Faridodin "Fredi" Lajvardi KD7WKD
Unread 01-03-2011, 16:04
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Grab Tube on the Run!
I can't get over how cool your arm design is. This is something I am definitely going to file away for another year. I wish you the best of luck this season.
Unread 01-03-2011, 17:49
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Looks great and fast.
I hope you will be covering the middle gears as they appear to be a pinch hazard.
Good luck
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 01-03-2011, 18:56
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Love how fast that arm can move from top to floor=loading position.
Unread 01-03-2011, 22:09
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
I'm a huge fan of spatula manipulators, maybe for the simple reason that we have one too
Unread 01-03-2011, 23:01
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Love the arm action, beautiful!
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-03-2011, 01:05
Carter12s's Avatar
Carter12s Carter12s is offline
FRC #2036 (Black Knights)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Smile Re: Grab Tube on the Run!
Wow that is cool. Can I make sure I am getting this right thou? you have a stationary gear mounted at the pivot point of you shoulder, so that as you rotate, the chain linkage from this gear to the wrist would keep the wrist at a constant relative angle, except that by using two different sized gears you get the angle of the wrist to change as a function of the angle of the shoulder! That is really impressive!
The only place I have seen a similar system is inside the explosive ordinance disposal arm used on Foster-Miller TALON robots. Even thou I work with a talon and the arm almost every day, I never thought to use it on our FIRST robot, and the TALON system is simpler since because they use same sized gears they simple keep the joints relative angles the same.
That is just fantastic to see! If I can ask what gave you the idea to use a linkage like that?
Programing is the real way to build a robot.
Unread 02-03-2011, 01:50
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
I have seen similar techniques used before, It is a cool way to do it, RUSH 2007 pre-ship had the same concept, but using timing belts instead the upper joint was eventually cut for weight. This year 3450 is doing the same thing but with steel cable and our pivot point is at the base, so we have two longer joints. It is basically just a four bar linkage but the chain/belt/cable act as your bars.
I like the design looks cool, looking forward to seeing more.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 02-03-2011, 02:23
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Love the arm design. It might just be the video, or me, but it seems that your drive is twitchy at low speeds when you came up to the peg. Looking great!
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 02-03-2011, 03:28
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
That analysis of our arm is correct; the static sprocket at the top of the mast provides the rotation for the secondary arm member. There is a ratio of 1.5:1 to give the arm the motion seen in the video.
Not quite sure exactly where the idea came from... to quote professor Farnsworth: "It came to me in a dream, and I forgot it in another dream". I think SPAM's robot from '07 may have played a subliminally inspirational role.
We're hoping that everything will pan out well for the AZ regional in a couple of weeks. The bot in the video is the practice robot; we still have to adapt everything we learn from it to the competition bot on Thursday morning!
