Go to Post Car Nack called. He said get off his lawn. - Taylor [more]
Unread 27-02-2011, 11:30
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Datasheet for Yaw Rate Gyro Analog Devices PN AD2230?
Does anyone know where I can get a data sheet for the
Yaw Rate Gyro Analog Devices PN AD2230 that was in the 2008 KOP?
Thanks
Unread 27-02-2011, 11:42
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Datasheet for Yaw Rate Gyro Analog Devices PN AD2230?
PN is AD22304
Datasheet: http://www.ifirobotics.com/docs/anal...0Datasheet.pdf
The 2008 Sensor Manual also has some information about the gyro:
http://usfirst.org/uploadedFiles/Com...sor_Manual.pdf
Unread 27-02-2011, 16:34
Japper's Avatar
Thanks Kevin and good luck to you this year
Unread 01-03-2011, 14:18
Japper's Avatar
The sensor manual contains a link that is no longer available:
www.usfirst.org/frc_gyro.
What is missing is the pin outs to the gyro PCB. Does anyone have this info?
thanks again
Unread 01-03-2011, 16:17
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
The information is printed right on the board. BRW is black, red, White. Black is ground, red is +5 volts, and white is the signal. There are two connectors, one is the gryo data and the other is temperature.
-Hugh
Unread 01-03-2011, 16:31
The missing link is to the datasheet for the actual chip. It wouldn't tell you anything about the PCB or how to connect to it. The information you want is the third paragraph of the YRG page of the 2008 sensor manual:
The Yaw Rate gyro receives 5V from the RC and connects to two of the robot controller’s analog inputs. Please note that the output labeled “T” is for “Twist” or rotational velocity. The output labeled “R” is “Relative Temperature”.
It doesn't explicitly tell you that "G" means Ground and "5" means 5 volts, but I think that's pretty obvious from the legend on the board itself.
Unread 01-03-2011, 17:16
scooperman's Avatar
scooperman scooperman is offline
FRC #1523
scooperman is an unknown quantity at this point
just in case you have an older unit, check the 2006 sensor manual.
http://www2.usfirst.org/2006comp/oth..._Operation.pdf
The YRG board had a typo in the silkscreen, wrong pin labels.
Unread 01-03-2011, 18:37
Japper's Avatar
thanks guys!
