Re: Cart Rules
Re: Cart Rules
If you are making your cart from scratch, consider using it as a work table in the pit. That is, it must be high enough to allow you to work comfortably but not so high that the robot on top doesn't go through a door. Many venues have access to the field through doorways between the pits and the field.
Re: Cart Rules
hey guys the yellow wagon from lowes painted your team color works great
Re: Cart Rules
but of course get your hands on a wheelchair and there are endless possibilities
Re: Cart Rules
Depending on how the robot is balanced on the cart, it may not be permissible because of safety precautions. Common sense safety is always imperative.
Re: Cart Rules
We made our cart in '08, it has an old electric wheelchair motor to drive it and a scissor lift table so we can work on the robot in our pit and bring it down when we are transporting it. But like previously said carts are an off season project.
#7
Re: Cart Rules
That might be difficult for a lot of teams that have tall arm mounts, such as ours. Our cart that we have is just high enough so we don't have to bend over to work on the robot, but the robot is definitely is too tall for a door when it's on the cart.
#8
Re: Cart Rules
That may be problematic. There are venues that we've been to where you need to fit through a normal doorway. I don't think you're going to want to have to stop, take your robot off your cart, then put it back on once you are through the door. I'd reconsider the height.
#9
Re: Cart Rules
It might be possible to modify the cart so that the robot lies down on top of it, That would allow you to use the same cart to hold and move your robot.
#10
Re: Cart Rules
#11
Re: Cart Rules
We use something very similar to this. Every year we change it a bit, adding on supports so that it holds up the robot in the right places, but it has worked well in the pit. Being able to adjust the height is very convenient - we can raise it if we need to work on something lower down on the bot, but when the table is all the way down, the robot easily fits through doors.
