Go to Post If you can spare 2 minutes (And I know you can, because the season’s over and you’re STILL on Chief Delphi) - LVMastery [more]
Unread 01-03-2011, 21:49
Team 2524 Team 2524 is offline
FRC #2524
Team 2524 is an unknown quantity at this point
Connecting PWM cables to speed controllers (Jag/vic) is a hassle/problem
Is there some sort of methodology to connecting PWM cables to the DSC? I spend half the time trying to place the cable and only a few minutes in testing out code . This is a big problem since we're short on time at the competition.
Does anyone have any advice on how to make the connection easier?
In my experience, the victors are SO MUCH easier to connect the PWM cables. The jaguars we had a big problem with it >.<.
edit: not DSC but jag/vic
Unread 01-03-2011, 22:11
Re: Connecting PWM cables to speed controllers (Jag/vic) is a hassle/problem
Why do you need to change PWMs after you wire the robot? The Clip on the side of the DSC is there to keep the PWM cables in place. Simply push the tab to the side and the PWM cable should just pull out.
Unread 02-03-2011, 04:44
FRC #2524
Sorry, What i meant to say was
"Is there some sort of methodology to connecting PWM cables to the jag/vic? "
The DSC sides we don't have a problem with. It's removing the cables from the speed controllers and putting them back on.
Unread 02-03-2011, 06:02
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Though this is avoiding the issue completely, CAN instead of PWM. A lot less messy and easier to change connections when all you have is 4-pin phone cables between the jaguars and the 2CAN.
Unread 02-03-2011, 06:43
FRC #2524
That would be the logical thing to do but it's so late already.
Unread 02-03-2011, 08:03
Practice, practice, practice.
Unread 02-03-2011, 08:32
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You may be doing something incorrectly or the hard way if you are having difficulty inserting the male PWM pins into the Jaguar. In my experience it is much more difficult to assure that the pins actually make it into the receptacles in the Victor than it is in the Jaguar, where the housing is much shallower.
The cable should just plug right into the Jaguar, then you can slide the cable behind the plastic strain relief hook directly in front of the connector. To remove the cable reverse the process, slide the wire out from behind the hook then simply pull it up vertically out of the socket.
Are you sure you are plugging the PWM cables into the right place on the Jaguar and in the correct orientation? Are you using PWM cables that have a different housing than those provided in the Kit of Parts?
Unread 02-03-2011, 09:03
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
While I agree with this, CAN is not for everyone. We used it, but our new programmers took a bit of time learning the programming behind them, such as catching exceptions or the setup of the Jags. For certain applications, PWM is easier.
Unread 02-03-2011, 09:30
Some of the PWM cables have an extra ridge of plastic on them. Snip it off and they should go in easier.
Although I'm a huge fan of CAN, post-ship isn't the right time to start on it.
Unread 02-03-2011, 12:06
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Agreed. The victors we're using this year (884's ordered this year) don't seem to like our male PWM connectors - we have to unplug/plug/unplug/plug until the Victor finally makes contact and shows the "idle" light config. I thought for sure there was something in the hole, but I didn't see anything preventing the Victors from mating correctly with the PWM cables. I thought it was the cables, too, but perfectly working cables (5-6 of them) on other devices (such as other Victors and Jags) wouldn't even make the proper "connection." I don't know why it's such a pain in the butt, but I promise we're not unplugging them. Ever.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 02-03-2011, 22:06
FRC #2524
We ordered 2 new jaguars and they work fine. i hope we don't run into this issue at the competition
Out of the 4 jaguars we received in the KOP, only one is still working. one blew out and the other two are the ones we're having trouble with.
Also Danny Diaz I've noticed that issue with the new victors too. We are still able to plug it into the slot.
