Go to Post Hey, I'm not my dad, I dont know anything! - Lil' Lavery [more]
Unread 02-03-2011, 00:06
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
flatten image for Dashboard
I'd like to send modified images to the Dashboard using the same mechanism that the "send to PC" VI uses.
In order to do that, I need to compress the image the same way the camera does.
I've tried with the IMAQ compression, but didn't have success with the default Jpeg compression values.
I've uploaded my test VI, and would appreciate any suggestions or insight.
Thanks!
-- Marshal Horn
Unread 02-03-2011, 12:31
ATH1RSTYM00SE's Avatar
ATH1RSTYM00SE ATH1RSTYM00SE is offline
Stephen Fastow
AKA: Stephen Fastow
FRC #5254
ATH1RSTYM00SE is on a distinguished road
Re: flatten image for Dashboard
I can exactly see your code cause im on a school sanctioned laptop but what i believe you need to do is in your teleop vi whatever you want to send to the dashboard flatten it to a string and use the block set user data high. Then go to your dashboard project and find where the user dat high comes out. There should be a disabled block around an unflatten from string block. remove the disabled block and attach whatever kind of indicator you want. If you want to add more then one thing to the dashboard You have to flatten everything in teleop, and bundle it. in the dashboard project you need to unbundle the unflatten from string, set the data type to bundle and specify what kind of value you will be passing by attaching things to the bundle Then you can attach indicators to the unbundle. Hope this helps and is clear considering i did it entirely off of memory
Unread 02-03-2011, 19:52
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
That is a thorough description of how to send the camera image using the Dashboard High Priority data.
Unfortunately, that's not what I'm asking.
The "send image 2 PC" VI called in the "Open Camera" VI sends the camera image, still compressed, to the Driver Station IP address on TCP port 1180.
This works with the default dashboard. I see advantage in using the default dashboard.
What I plan to do is modify the "send image 2 PC" so that I can send modified images (showing the target as a green rectangle) when I'm processing to find the target, and send the normal image when I'm not.
In order for the Driver Station to receive these modified images as it normally does, they need to be encoded the same way. THAT is what I'm having trouble with.
-- Marshal Horn
Unread 03-03-2011, 09:07
Such a modification would be a large change to how it does what it does, and would greatly increase the amount of processing required on the robot. The typical advice is to send the target coordinates in the dashboard data and let the Dashboard program overlay the rectangle on the received image.
Unread 03-03-2011, 11:16
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
That's a good idea. Thanks.
-- Marshal Horn
