Re: Watchdog expiration problems in teleop
So just to understand, do you ever get "Watchdog Expired" in the window that says "Teleop Enabled"? i.e. do you ever lose Communication/Robot Code at unexpected times? And can you state the exact message you are getting in the Diagnostics Panel? I understand that you will probably not be able to do this till your first event (tomorrow) but I (crosses fingers) think that you are just getting the User Watchdog expiration message, which is not an issue.
The Periodic Tasks.vi is another labview file in the same folder as the Begin, Teleop, Autonomous and Finish.vi's. |
I was using a new laptop with a clean install of windows xp and with the fire wall off. I had the lastes driverstation software. I was getting watchdog expiration every 2 minutes. I used last years classmate with a broken ethernet port which was hot glued, I was able to go 25 minutes with no watch dog problems. I guess it might be communication time outs. Thank you so much for your time
