Go to Post When you're in a field as deep as the Championship go offensive or go home. It's that simple. - thefro526 [more]
Unread 02-03-2011, 10:13
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: how to remove deployed code?
Ah. You can prevent code from running automatically by unchecking "always run code on startup" in the cRIO reimaging tool.
(When you deploy code as startup, it is startup. When you do a temporary deployment, it unsets that other code as startup. The "always run code on startup" searches for something called "startup.rtexe" if there is no code set as startup.)
-- Marshal Horn
