Go to Post "at some point in the next six weeks you are going to start feeling like you are involved in a robot building contest. Then you are in serious trouble" -Dean Kamen - KenWittlief [more]
Unread 01-03-2011, 17:32
Sixis's Avatar
Sixis Sixis is offline
AKA: John
FRC #3419 (Rohawks)
Sixis will become famous soon enough
Cart Rules
Hey guys, for some reason I keep thinking that there was some rule this year that prohibited carts from having more than 2 wheels. A quick check of the manual/ CD search didn't turn up anything. Can anyone quickly sort this out for us?
Unread 01-03-2011, 17:37
Re: Cart Rules
There are few rules governing carts. The ones that are there are mainly practical limitations, as follows:
Originally Posted by Administrative Manual, Section 4.3.2
 Carts must remain in the team pit area when not in use for robot transportation;
 All carts should fit through a standard 30-inch door;
 Wheels on the cart must not damage site flooring; and
 Do not add music or other sound devices to the cart.
Nothing about number of wheels. (Also note--carts may need to traverse cable protectors/slightly uneven flooring.)
I would also add that height should be considered in the "fit through a standard door" requirement.
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Cart Rules
No such rule, which doesn't make sense anyway.
(since 2004)
Unread 01-03-2011, 17:59
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Cart Rules
Too bad so many teams ignore the noise ordinance for the carts.
I still don't understand the whole tricked out robot cart thing. Why not put more time and energy into building a better robot?
Unread 01-03-2011, 19:14
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Re: Cart Rules
Building a cart is a great off-season project for the metal shoppers.
Our cart has six wheels, with the center ones dropped.
Unread 01-03-2011, 19:18
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Cart Rules
How would a 2 wheeled cart work? I would thing it would be frustrating, but I don't know. A self balancing segway type cart would be interesting though.
Unread 01-03-2011, 19:47
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
Re: Cart Rules
very large gyroscopes they are so cool
Unread 01-03-2011, 19:57
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Cart Rules
A wheelbarrow
Unread 01-03-2011, 23:08
Re: Cart Rules
If you are making your cart from scratch, consider using it as a work table in the pit. That is, it must be high enough to allow you to work comfortably but not so high that the robot on top doesn't go through a door. Many venues have access to the field through doorways between the pits and the field.
Unread 01-03-2011, 23:11
Captaindan's Avatar
Captaindan Captaindan is offline
AKA: Daniel
FRC #0364 (Team Fusion)
Team Role: Driver
Captaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the roughCaptaindan is a jewel in the rough
Re: Cart Rules
hey guys the yellow wagon from lowes painted your team color works great
Unread 01-03-2011, 23:13
Captaindan's Avatar
AKA: Daniel
Team Role: Driver
Re: Cart Rules
but of course get your hands on a wheelchair and there are endless possibilities
Unread 01-03-2011, 23:25
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Cart Rules
Depending on how the robot is balanced on the cart, it may not be permissible because of safety precautions. Common sense safety is always imperative.
Unread 02-03-2011, 00:45
zachmartin1806's Avatar
zachmartin1806 zachmartin1806 is offline
FRC #1806 (S.W.A.T. Robotics)
zachmartin1806 has a spectacular aura aboutzachmartin1806 has a spectacular aura aboutzachmartin1806 has a spectacular aura about
Re: Cart Rules
We made our cart in '08, it has an old electric wheelchair motor to drive it and a scissor lift table so we can work on the robot in our pit and bring it down when we are transporting it. But like previously said carts are an off season project.
Unread 02-03-2011, 11:27
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Re: Cart Rules
That might be difficult for a lot of teams that have tall arm mounts, such as ours. Our cart that we have is just high enough so we don't have to bend over to work on the robot, but the robot is definitely is too tall for a door when it's on the cart.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 02-03-2011, 15:54
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Cart Rules
That may be problematic. There are venues that we've been to where you need to fit through a normal doorway. I don't think you're going to want to have to stop, take your robot off your cart, then put it back on once you are through the door. I'd reconsider the height.
