Go to Post As Grandma used to say, "empirical data is better than no data at all." - dlavery [more]
Unread 11-11-2002, 13:19
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
I've never tried this either, but I think I will this shower. I'm a bit af an amatuer photographer, so here's some tips:
Your standard camera, on a tripod, is probably best suited for this kind of thing. Probably, very few digital cameras allow sufficiently long exposures.
[edit] The standard camers is an SLR, I assume [/edit]
You actually don't want to magnifiy the sky. No telescope needed. You need to observe a large area and gather all the light there possible, so a good lens would be a standard 50mm f/1.8 , and even wider if you want.
The camera needs to be able to take long exposures. See if your camera has a "bulb" or B setting, where you push the shutter down and it stays open as long as the shutter is pressed. If it's an electronic SLR, it might allow long exposures without the B setting. To keep the shutter open with bulb, you need to get a cable shutter release, so the camera doesn't shake while it's pressed. In a shower, 5-10min of exposure should caputre alot of meteors.
Also, you need some really fast film, like ISO 1600 or 3200 . You can get some probably at any little camera shop.
And whever you do, point the camera away from the radiant.
Good luck!
