Re: zomB Dashboard
Download v0.8.1.386 |
Re: zomB Dashboard
Okay, it worked on Firefox with the frc/FRC account, but we still couldn't get an image on the ZomB dashboard using your latest package.
Did the camera + PC + network switch/hub setup work for you? If so, do you mind uploading a simple .zaml file that only has the video field? It could be that there are some obvious things missing from our design. |
Re: zomB Dashboard
Yes, I have been able to get it working using that setup.
pop this in testing.zaml and double click it: Code:
<ZomB:DashboardDataCanvas xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:ZomB="clr-namespace:System451.Communication.Dashboard.WPF.Controls;assembly=ZomB" xmlns:ZomBDS="clr-namespace:System451.Communication.Dashboard.Net.DriverStation;assembly=ZomB.DriverStation" Height="400" Width="1024" InvalidPacketAction="Ignore" DefaultSources="zomb://10.31.26.2/DBPkt;" Team="3126"><ZomB:CameraView Name="Zdb49ae27cb754a1d" Canvas.Top="150" Canvas.Left="10" ShowReset="True" VideoSource="MJPEGStream" VideoSourceArgs="10.31.26.20" Height="240" Width="320" RenderTransformOrigin="0,0" /></ZomB:DashboardDataCanvas> Code:
<ZomB:DashboardDataCanvas xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:ZomB="clr-namespace:System451.Communication.Dashboard.WPF.Controls;assembly=ZomB" xmlns:ZomBDS="clr-namespace:System451.Communication.Dashboard.Net.DriverStation;assembly=ZomB.DriverStation" Height="400" Width="1024" InvalidPacketAction="Ignore" DefaultSources="zomb://10.4.51.2/TCP;zomb://10.4.51.2/TCP2;" Team="451"><ZomB:CameraView Name="Zdb49ae27cb754a1d" Canvas.Top="150" Canvas.Left="10" ShowReset="True" VideoSource="MJPEGStream" VideoSourceArgs="10.4.51.90" Height="240" Width="320" RenderTransformOrigin="0,0" /></ZomB:DashboardDataCanvas> If this does not work for you, open C:\windows\assembly and find ZomB. If there is more than 1, uninstall all but 0.8.1.0. If you are still having troubles, make sure IE does not have a proxy set, connect the camera to the router, and the computer to the router, and try again. You can also try installing SlimDX, and reinstalling ZomB. final idea: download Visual Studio C# express edition, and I can use LogMeIn or VNC to see what your problem is (PM me if so) |
Re: zomB Dashboard
after working on another computer, and as we calibrate all our stuff on another computer, whenver installing your Visual ZomB eight, also having tried downloading every version 0.7 and up chronologically, it gives an error message, meaning we can't it at all any suggestions?
Re: zomB Dashboard
what's the error message? or is it the standard windows error box? if the standard box, view details and either copy it all out to a PM, or find the first part of the stack trace (should contain System451.Communication.dashboard in it) Also note, to downgrade, uninstall your version, delete any extra files in C:\Program Files\ZomB\, open C:\Windows\Assembly, and delete all ZomB versions, then install the version you want. |
