Go to Post Ah, drills & motors. Brings back old memories of FIRST - nparikh [more]
Unread 07-11-2002, 11:19
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
Pnuematic programming
Is there any resource out there for pnuematics code? I don't quite understand how the pressure switches work, but the pnuematics manual doesn't mention any pinouts or where to wire the switches.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 07-11-2002, 12:54
Matt Reiland's Avatar
'The' drive behind the drive
Do a quick search of the forums, it will bring up many threads.
The pressure switch is a digital input that should be shown how to wire a digital input in the manual for the control system, you can pick the input. We had no pnuematics last year but I think it was adjustable for the pressure that will trip it. Then you can Turn on/off the compressor based on the switch or two switches (one for high, one for low) I think there are also a few white papers on Compressor programming
Check this white paper on the sixth page of white papers for an example
Description:
Pneumatic Wiring and Programming
originally submitted: 01.18.2001
by Dan Grostick
Unread 07-11-2002, 13:36
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
http://www.chiefdelphi.com/forums/sh...t=pneumati cs
The pressure switches are like any standard digital input. There's no + or -, no specific way to wire it or hook the tubing up for the pneumatics.
When it needs to be filled, the pressure switch will be closed, it will show up as a 1 in programming (current).
When it is filled, the pressure switch is open, which is a 0 in programming (no current).
The rubber stopper on top is removable. Underneath it is a screw that can be adjusted. Tightening (clockwise) will raise the tripping pressure. Loosening the screw (counter-clockwise) will lower the pressure.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 07-11-2002, 14:13
f22flyboy's Avatar
cool thanks
Team 540 Forums
Unread 11-11-2002, 14:37
f22flyboy's Avatar
I realized that one page didn't print when I printed out the control manual - the page with ports and pin-outs for switches. Thanks for your help anyway
Team 540 Forums
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
