Go to Post That goal is going to commit suicide by the end of the regional........so many balls @_@... - DanDon [more]
Unread 02-03-2011, 16:03
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
New D-Link bridge problems
Before, I had a problem with the bridge in which when I would try to access the configuration page it would show up an emergency web server. But I fixed that with the file that I downloaded from the first website. Now the problem is that I followed each and every step on the .pdf file "how to set up your radio" but it never connects to the router on bridge mode for some reason, even when I put it on AP mode I never see it with my computer's wifi adapter
Unread 02-03-2011, 16:04
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: New D-Link bridge problems
Is the frequency of the bridge correct? Not being on 2.4GHz might be your problem.
Unread 02-03-2011, 16:29
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
It is at 2.4 in AP mode. Only in Auto mode it goes to a third option "2.4GHz/5GHz"
Unread 02-03-2011, 16:52
Sean1038 Sean1038 is offline
FRC #1038
Sean1038 is an unknown quantity at this point
You should set up your bridge for bridge mode, not access point mode.
Unread 02-03-2011, 17:01
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
i did though, i went to LAN settings and set a static IP 10.xx.xx.1 and an access point which is our router 10.xx.xx.4, still nothing
Unread 02-03-2011, 19:45
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Bridge mode is only used at competition (think old bridge). AP mode is for use outside competition (think putting the old router on your robot). The FIRST documentation has been updated and does a good job of explaining everything.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 02-03-2011, 20:10
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
I would use the old bridge but I want to use the new bridge in bridge mode at the competition so that I can hook up the camera to it so I dont have to deal with this problem I get with the robot disconnecting from the driverstation because of some exception error I get on windriver after 5 seconds of being enabled with the camera plugged.
Unread 02-03-2011, 20:14
AKA: Alex
I did not mean to use the old bridge (you have to use the DAP-1522 this year). The references to the old stuff was to give you an example of what the different modes do.
-Alex
Unread 04-03-2011, 15:31
krudeboy51's Avatar
Only Programmer
AKA: kory
FRC #0369 (369)
ok I managed to get the bridge working, thanks for all your help. One thing though, when connecting the camera through the bridge, is there anything I have to add to the code or driverstation to get a live feed?
Unread 04-03-2011, 21:53
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Well if anyone had bothered to go to usfirst.org they would now how to fix it
Directions: http://usfirst.org/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2011_Assets/Kit_of_Parts/How_to_fix_the_Emergency_Web_Server.pdf
