Go to Post Use checklists. If it's good enough for NASA, it's good enough for FIRST. - Rick TYler [more]
Unread 02-03-2011, 21:54
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: resetting window motor driven arm after each round
Originally Posted by Da Kid View Post
does anyone know about a gear box with a wormdrive in it that uses a cim motor? our mentor was thinking about doing this because of the cim motors' strength.
in a related matter, what would the gear ratio need to be for a denso window motor to rotate a 10 lbs, 50 in. arm that extends to 62 in? we want it to not put too much strain so that the thermal breaker doesn't get tripped. we do have a spring on the arm so that makes it a little easier, but what would the gear ratio be without the spring, just to be safe?
Just do the math. 10lb *16oz/1lb * 62in = 9920 oz*in. A window motor's stall torque is 1501 oz*in.
That means you need about a 7:1 reduction with a single window motor. That'll give you an angular velocity of about 12 rpm. You also should design it so that the window motors don't operate at their max stall torque, so you may actually need to increase the reduction some more or add another motor.
Unread 09-03-2011, 02:18
Torbots 1197 Torbots 1197 is offline
Chief Tormentor
FRC #1197 (TorBots)
Team Role: Communications
Torbots 1197 is an unknown quantity at this point
We're powering our arm through a combo of a fisher-price and RS-775 motors. The F-P is fed into a banebots P60 gearbox with a 20:1 reduction and the 775 through a P60 with a 16:1 reduction. The output of both motors are then fed into a torque summing gear that is also tied to a custom 30:1 worm gear setup. For us, this results in around 20 RPM at the output of the worm gear under a load.
If you're to just use one CIM motor to drive this setup, I'd expect a noticeable reduction in speed as you'll probably be driving the motor somewhat close to it's stall condition. Our arm is designed to still limp along even if one motor happens to die during a match. Don't be fooled by the size of the motor; the F-P motors have the highest power ratings of all the motors available to us.
Unread 09-03-2011, 06:14
Electrical Engineer
Rookie Year: 1995
Originally Posted by Torbots 1197 View Post
...Don't be fooled by the size of the motor; the F-P motors have the highest power ratings of all the motors available to us.
Brrraaappp! That's one down, Kitty Carlisle...
Are you saying that the posted motor specifications are incorrect?
The CIM has a peak mechanical power of 340W versus the FP at 292W. Add to this the additional gear reduction required to gear down an FP, and the CIM wins every time.
Now, if your intention is to build a smoke generator, the FP is a natural choice...
JMHO,
Mike
Mike Betts
As easy as 355/113...
Unread 09-03-2011, 07:17
Al Skierkiewicz Al Skierkiewicz is online now
I am guessing that the phrase "for it's size" was left out.
Unread 09-03-2011, 07:44
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Originally Posted by Nuttyman54 View Post
Team 190 is using a mechanical solution (see attached pictures)
Evan,
That has to be one of the coolest things I have seen. Great idea!
btw, I absolutely love your robot this year! Good luck at WPI this weekend.
Unread 09-03-2011, 09:07
Chris is me's Avatar
AKA: Pinecone
Okay, I'm not going to let 190 get all the "cool credit" anymore
Here's some pictures of our spring loaded window motor disengager. We use it to lower our arm after a match. We still have to power the robot arm to get it in exactly the place we need but we use it to save on time a little bit as well as making it easier to carry to the pits.
http://i.imgur.com/O1NR1.jpg
We have the window motor coupled to a 3/8 hex shaft, which drives everything. The "seam" in the sprocket is where our makeshift dog connects to the sprocket in order to drive it.
http://i.imgur.com/2NsiC.jpg
Here clearly shows how the dog and sprocket connect, transferring power to the shaft. There's a hex pattern in the sprocket, but it rides on a round portion of shaft so the arm can free spin when disengaged.
Unread 09-03-2011, 09:17
Pjohn1959's Avatar
Timing is everything....
My school is blocking the pictures, do you have any other way to display them?
